E7000 vs F5500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-29-2013, 10:46 AM - Thread Starter
Croathlete's Avatar
So I'm looking into either the PN64E7000 or the PN64F5500. Both can be had at the same price. The only difference I can find is that the E7000 series has the real black pro panel. The TV will be in a basement so maybe the panel difference won't matter. Does anyone know of any other significant differences between these two series? Processing? Brightness? Don't really care about the touch remote. I do like that the E7000 has side facing ports since it will be wall mounted. Any opinions would be greatly appreciated. Thanks in advance.
Croathlete is offline
post #2 of 2 Old 08-08-2013, 08:20 AM
ivision's Avatar
PN64F5500 with better sound effect system, "DTS Studio Sound" and also with "Game mode" features. Source link, http://www.zimbio.com/High-Definition+Television/articles/Qul7iesPxDy/PN64E7000+vs+PN64F5500?add=True
ivision is offline
Samsung Pn64e7000 64 Inch 3d Ultra Slim Plasma Hdtv , Samsung Pn51e7000 51 Inch 3d Ultra Slim Plasma Hdtv , Samsung Pn60e7000 60 Inch 1080p 600 Hz 3d Ultra Slim Plasma Hdtv , Samsung Pn60f5500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Un46f5500 46 Inch Class Smart Tv Slim Led Hdtv , Samsung Un32f5500 32 Inch 1080p 60hz Slim Smart Led Hdtv
