packaging of 65VT60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-01-2013, 07:37 AM - Thread Starter
jk_bama's Avatar
Quoted: 21 Post(s)
There was no plastic tape around the edges. Is this normal or did I get a used one from amazon?
jk_bama is offline
post #2 of 5 Old 08-01-2013, 09:15 AM
brehiser's Avatar
Quoted: 51 Post(s)
Liked: 37
Mine was new from Best Buy and only had the plastic tape along the bottom bezel.
brehiser is offline
post #3 of 5 Old 08-01-2013, 10:32 AM
njera's Avatar
Same for a new set from Paul's TV... tape only on the bottom. However, I did get a bonus handful of Mexican dirt in the bottom of the box. confused.gif Some dirt also was under the tape that secured the manual to the box, so I'm pretty sure the TV came from the factory that way.
njera is offline
post #4 of 5 Old 08-01-2013, 11:01 AM - Thread Starter
jk_bama's Avatar
Quoted: 21 Post(s)
thanks guys. Did not check the bottom bezel. Bottom is still in box.
My ST50 definitely had the plastic tape around the edges. Made a point to remove it before the 100 hour prep.
amazon would not deliver it to basement. Little disappointed but maybe that is normal procedure for them.
jk_bama is offline
post #5 of 5 Old 08-01-2013, 11:05 AM - Thread Starter
jk_bama's Avatar
Quoted: 21 Post(s)
another question --
Is it possible to record on USB from OTA broadcast onPanny 65VT60?
I know you could not do this on ST50 line.
jk_bama is offline
Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P65st50 Plasma Tv
