P50s30 Red Light constant - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-04-2013, 02:15 PM - Thread Starter
Lrenp's Avatar
Hello, I have a P50s30 that I was sitting watching and it made a loud "pop" noise and went off. The power light stayed on constant.
I unplugged it, let it sit and then plugged it back in. The power light comes on and stays constant but no reaction from the power button on the TV or the remote. I have taken the back off to examine the boards but dont see any burnt signs. Any advise would be appreciated!
Lrenp is offline
post #2 of 5 Old 08-05-2013, 11:00 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
OK, can you post a picture of the inside of your set? (the "chassis")
No blink/solid red LED on these modern TVs indicates: VSUS, VDA or 15V short.
PM me and I'll send you what service documentation I've got for these.
tom669 is offline
post #3 of 5 Old 08-06-2013, 08:13 PM - Thread Starter
Lrenp's Avatar
Here"s the pic of the inside tv3.jpg 10k .jpg file
Lrenp is offline
post #4 of 5 Old 08-07-2013, 07:22 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
I'm sorry you're going to need to post a picture with higher resolution. I can't see much detail on that image at all.
tom669 is offline
post #5 of 5 Old 08-07-2013, 07:20 PM - Thread Starter
Lrenp's Avatar
tv5.jpg 9k .jpg file tv4.jpg 9k .jpg file tv7.jpg 9k .jpg file Thanks for your help! I don't have a camera and my phone must not be good enough. My son took these with his much newer phone but I will find a camera if I have to.
ID:	71316   Click image for larger version
ID:	71317   Click image for larger version
Lrenp is offline
Panasonic Viera Tc P50s30 50 Inch Plasma Hdtv
