I just got a TC-P42S60 and I'm new to smart tv's and have a question about netflix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-06-2013, 01:56 AM - Thread Starter
jboom91's Avatar
Hey guys is it normal for other video settings to be disabled or not show up when using the netflix app built into the television. I'm wondering because I'm watching American Dad before it was widescreen so I have two black bars on the side and don't have an option to make the side black bars light grey or stretch the screen... will this hurt my new plasma?
Also I have pixel orbiter set to "on", when the only other option is "auto," is "on" the best option for keeping the screen from burning?
Thanks guys.
jboom91 is offline
post #2 of 5 Old 08-06-2013, 05:17 AM
*UFO*'s Avatar
Quoted: 465 Post(s)
Liked: 361
Thanks guys.
I personally would not run anything but full screen material that has no logos for the first 100 hours. Others say you no longer need to burn in a plasma, but I believe it will greatly reduce the chance of any permanent image retention down the road. Think plasma like a ton of tiny candles. When you first light the candle, it will burn fast and bright. Over time it will dim a little and burn much slower. If some candles are burning at a different rate then the others, you will have temporary or possibly (not very likely) permanent image retention.
jboom91 likes this.
*UFO* is offline
post #3 of 5 Old 08-07-2013, 08:10 PM - Thread Starter
jboom91's Avatar
I have another question hopefully if someone sees this thread. This tv is smart and has built in wi-fi, yet I cannot get it to connect to my hidden network. I enter in the name manually and say that its open and then the tv will not connect, I cannot find anywhere on the internet where people mention connecting smart tv's to hidden wi-fi networks, is it even possible?
jboom91 is offline
post #4 of 5 Old 08-07-2013, 08:25 PM
muffinmcfluffin's Avatar
Quoted: 223 Post(s)
Liked: 130
Maybe it's something you have to do on your router to make it visible or whatever.
jboom91 likes this.
Living Room: Samsung PN60F8500 PDP / Anthem MRX 720 / Klipsch RC-62 II / Klipsch RF-82 II (x2) / SVS PC13-Ultra / Sony MDR-7506 Professional / Sony PS3 / DirecTV HR44-500 / DarbeeVision DVP-5000 Darblet / Panamax M5400-PM / miniDSP UMIK‑1 USB
Bedroom: Samsung PN59D7000 PDP / Energy Power Bar Elite Soundbar & SW / Astro A50 / Sony PS4 / DirecTV C41W-500 / DarbeeVision DVP-5000 Darblet / Hauppauge HD PVR 2
Classroom: SMART Board X800 / Yamaha RX-V667 / Insignia NS-B2111 (x2) / SVS SB-2000
muffinmcfluffin is offline
post #5 of 5 Old 08-08-2013, 09:29 AM
Jorsher's Avatar
Why do you have hidden SSID? It's pretty much useless as far as security. Show the SSID, and use WPA2 encryption.
What I'd suggest, if you really want to avoid that, is to make the network visible long enough to test the connection. If it works, you'll know the TV doesn't handle hidden networks too well smile.gif
jboom91 likes this.
Jorsher is offline
Panasonic 42 Inch Plasma Hdtv Tc P42s60
