ST50 - Fixing Scuff On Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-10-2013, 09:41 AM - Thread Starter
asdfgh's Avatar
Hi, we got some scuffs on the screen when we were moving some stuff, and I was wondering if there is a way to fix it. I was thinking about trying eyeglasses cleaner, but I have heard that the outer screen on Panasonic plasmas are made of a special material. I want to make sure before trying anything and ruining it further.
asdfgh is offline
post #2 of 2 Old 08-10-2013, 10:13 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Once the soft delicate screen coating has been damaged, there is no way to fix. It's like a super-thin rubbery film and anything you attempt will just make it look worse. I would not use any sort of cleaner on it - just use plain water, and do not rub hard - use a very light touch. But since it's scuffed, there's really nothing you can do to reverse it.
The only way to fix it is to replace the outer screen with a fresh new one.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Panasonic Viera Tc P65st50 Plasma Tv , Panasonic Viera Tc P60st50 Plasma Tv , Panasonic Viera Tc P55st50 55 Inch Plasma Tv , Panasonic Viera Tc P50st50 Plasma Tv
