Can you identify what this is? (dead/stuck pixels?) - AVS Forum | Home Theater Discussions And Reviews
Old 08-14-2013, 02:18 AM - Thread Starter
Gempulse's Avatar
Here is a picture: http://i.imgur.com/kn99FGy.jpg
It's on my VT60. It doesn't look like a dead or stuck pixel to me. It looks like a diagonal slash through three pixels.
Gempulse is offline
Old 08-14-2013, 05:47 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
It's more likely a foreign object that's between the outer glass and the face of the plasma panel. Through the years there have been random reports of tiny pieces of cardboard trapped between the layers of glass that apparently happened during final assembly. Look at it with a magnifying glass and maybe use a flashlight at angles and see if you can induce a shadow (which would help verify it's something in there and not an actual defect). It could also be something that's trapped under the louver filter coating when it was applied.
Regardless, i'd call Panasonic and report it. A technician will remove the outer glass and determine what it is and take it from there. Hopefully it's something stuck inside that can simply be removed. If he cleans the inside of the glass and/or the face of the panel, make double darn sure that it is streak-free etc before he re-assembles the TV.
Also if you do call for service, leave the TV OFF for several hours before the technician is scheduled to arrive so that the panel is stone cold. Cleaning hot or even warm glass often leaves streaks since the heat dries the liquid before you can wipe it away (BTDT).
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 08-14-2013, 09:04 AM - Thread Starter
Gempulse's Avatar
Thanks, Randy. After further inspection, it appears you are indeed correct. With the TV turned off, I shined a flashlight towards the affected area and there is something lingering behind the glass. I called Panasonic and they set up an appointment for a technician to come to my home.
Thanks for bringing this to my attention. If it were a stuck pixel, I would just have to live with it. But since it seems like it is an easier kind of problem to solve, why not take advantage of my warranty?
Gempulse is offline
Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv
