Unable to connect to Netflix on Panasonic TC-P55VT50 Plasma TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 08-15-2013, 02:00 PM - Thread Starter
thor3's Avatar
For the past few months I've been watching Netflix on other devices, but decided to give it a go again on my TC-P55VT50. I hadn't had issues in the past, but now get a message that the app can't connect to Netflix. I've read a number of posts that lead me to believe this is at least a known problem, and is similar to one that has been experienced with the Panasonic BDT220 Blu-ray player (which I also have, but don't have this issue).
To troubleshoot, so far I've:
1. Confirmed the network setup is correct, and that everything else on the TV can access the LAN & WAN successfully; I've also reserved an IP address for the VT50.
2. Confirmed the Netflix app on three other devices, which are on the same LAN, can connect to the service without issue.
3. Deactivated the Netflix app on the VT50 numerous times using the Up, Up, Down, Down, etc. sequence.
4. Factory reset the VT50.
5. Connected the TV via wired connection instead of wireless.
So far nothing has worked to fix this problem; I get the message that the app can't connect to the service almost immediately after starting it up, so haven't even been able to try and re-register the VT50 with Netflix. The error message I see when I go to the deactivation screen is: "NBP / 1 / Unable to connect to functioning local backend /".
Has anyone had this issue and fixed it? Any other recommendations or guidance would be great.
thor3 is offline
post #2 of 19 Old 08-26-2013, 03:54 AM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
Any firmware updates available for your set ? If you have a PS3 it will usually give the best PQ with Netflix than anything else including smart sets and BD players 2nd in PQ would be a ROKU . Ps 3 is the best streamer on the planet. different devices use different methods as probably already know .
tubetwister is offline
post #3 of 19 Old 08-26-2013, 12:11 PM - Thread Starter
thor3's Avatar
Thanks for the reply. I am up to date on firmware. I don't have a PS3, but usually watch Netflix on my TiVo Premiere 4. It has great quality too, and streams in 1080p unlike my other devices, even though they supposedly have the ability. My issue, however, is that on occasion my Internet connection chokes, and the resolution will constantly change back and forth between 1080p to 1080i, which makes it distracting to watch shows, as my TV screen blacks out for a few seconds with each change. When this happens I switch to another device I know won't try to stream in 1080p, which so far has been my Blu-ray player. The Netflix UI is however pretty slow on this player, and as it's much faster on the TV, I was hoping to use that as a backup instead. Plus, if something is broken I'd like to find out now, before my TV warranty runs out.
thor3 is offline
post #4 of 19 Old 12-15-2013, 02:13 PM
PaulForgey's Avatar
same problem here on my P55VT50. It was always flaky for me, but the latest firmware update completely broke it. Given I have at least three other devices in my system which work with Netflix just fine, I've pretty much given up myself.
So I think your TV may be just fine (all the other internet clients work fine and the TV itself otherwise works great), but the Netflix client is, unfortunately, too buggy to use.
PaulForgey is offline
post #5 of 19 Old 12-16-2013, 03:35 AM
dajiahuanle's Avatar
I know won't try to stream in 1080p, which so far has been my Blu-ray player. The Netflix UI is however pretty slow on this player, and as it's much faster on the TV, I was hoping to use that as a backup instead. Plus, if something is broken I'd like to find out now, before my TV warranty runs.
CjDQqc
dajiahuanle is offline
post #6 of 19 Old 12-16-2013, 07:02 AM - Thread Starter
thor3's Avatar
See if this solution works for you:
http://www.avsforum.com/t/1274332/netflix-on-viera-cast-television-showing-cannot-connect-to-home-network-error#post_20182989
thor3 is offline
post #7 of 19 Old 12-16-2013, 12:12 PM
PaulForgey's Avatar
So far, yes! Thank you!
post #8 of 19 Old 12-19-2013, 06:28 AM
I can connect on my tc-50ps64 but the picture quality on  ONLY the netflix app is 480.  All the other apps work in HD.  Any solutions?  Its not my ISP as my apple tv and blurry player stream netflix in hd.
Michial Brown is offline
post #9 of 19 Old 12-19-2013, 08:17 AM
absurd_username's Avatar
Log in at www.netflix.com / Your Account / Your Profile / Playback Settings
Double check that you aren't on 'Low' (Basic Video Quality, up to 0.3GB per hour).
Changing this setting from Auto to Low makes Netflix on my VT60 go from 1080 to 386. Yuk.
absurd_username is offline
post #10 of 19 Old 12-19-2013, 08:35 AM
Thanks. I already moved it from auto to high. Whether on auto or high the resolution is pathetic. It's not a problem with my tv I don't think because everything else streams hd. Or is it my tv?
post #11 of 19 Old 12-19-2013, 03:20 PM
Give Netflix Support Chat a whirl?
https://help.netflix.com/help
Just a thought...is your TV Netflix streaming wireless? Check your wireless connection in your room. I have a room at my house that is simply a wifi dead zone for whatever reason...lead paint in the walls?
Use speedtest.net app to test wireless speed at your TV location..
If you have an Android phone or tablet use Wifi Analytics Tool to see if you are on a crowded channel. https://play.google.com/store/apps/details?id=com.pinapps.amped&hl=en If you are on a crowded channel try changing the channel you are broadcasting on your router.
If wireless to your TV is weak, try Powerline Ethernet: http://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=powerline+ethernet&rh=i%3Aaps%2Ck%3Apowerline+ethernet
post #12 of 19 Old 12-19-2013, 03:37 PM
Thanks. Like I said when I stream the other apps on my panasonic viera ie Hulu YouTube and amazon instant it's hd so it's not a bandwidth issue.
post #13 of 19 Old 12-19-2013, 04:26 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Who is your ISP? Netflix receives a lot more traffic then any other streaming service and without Open Connect you will periodically experience lower quality streams. How often you receive HD quality usually depends on you ISP's CDN capabilities, not your down load speeds. I try to encourage anyone who has these issues with Netflix, to contact their ISP and tell them you want Open Connect.
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #14 of 19 Old 12-19-2013, 04:37 PM
Netflix is HD on my iPad, Apple TV, sony bluray player just not my Panny plasma. All those devices are on the same ISP and network wirelessly
post #15 of 19 Old 12-19-2013, 09:52 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
My S60 always plays Super HD. If those devices are in the same location as your TV, which is set up properly with your network, then I suggest you contact Panasonic and tell them we have a problem Houston.
mailiang is offline
post #16 of 19 Old 01-24-2014, 10:50 PM
PaulForgey's Avatar
Well, it worked for a while. Another firmware reset got it going again. I think it may just keep in this pattern.. fortunately, just about every component in my system has a Netflix client in it, although it was convenient to use the TVs. Oh well.
post #17 of 19 Old 10-01-2014, 07:12 PM
Liked: 0
Clock settings
I have been having the same issue with Netflix on my Panasonic Plazma. Somehow my clock settings were set to manual and lost settings. Setting it to automatic fixed the Netflix issue. Manually setting it to the accurate time would have probably also done it. Netflix may be using the time to help validate/verify something, probably your location or time zone – who knows? Anyway, if you haven't already fixed the issue, check your clock settings and then try Netflix again.
apmeyer is offline
post #18 of 19 Old 09-15-2015, 09:48 PM
mantar's Avatar
Quoted: 43 Post(s)
BINGO!!! The CLOCK issue was what fixed it for me. Except mine was still auto. So I set it to Manual, then set it to Auto again. Netflix connection doesnt get hung up.
mantar is offline
post #19 of 19 Old 01-03-2016, 04:20 PM
AlexBen's Avatar
Quoted: 37 Post(s)
http://www.avsforum.com/t/1274332/ne...#post_20182989
Thank you for providing the link/jump. Worked for me very well.
AlexBen is offline
Panasonic Viera Tc P55vt50
