PDP-4360HSD Pioneer Plasma - AVS Forum | Home Theater Discussions And Reviews
Old 08-15-2013, 07:55 PM - Thread Starter
Roverton1's Avatar
Im trying to do the closed caption set up. The manual states to go to Main Menu then to Tuner Set up.
The Tuner Set up states " Current setting do not allow selectiona dnd adjustment." How do I enable the Tuner Set up to be able to do the closed caption. Any suggestions . Thanks, Lowell
Roverton1 is offline
Pioneer Pdp 4360hd 43 Inch Purevision Widescreen Plasma Hdtv
