TC-P65VT25 Network Issue - AVS Forum | Home Theater Discussions And Reviews
Old 08-16-2013, 08:14 PM - Thread Starter
Ckreiter's Avatar
I recently moved cross country and had my P65VT25 packed in the original box. Upon setting it up, everything seems to work except for my LAN port. This was working before the move. With a good LAN cable plugged in (the connection is fine with my DVD player), the network connection test returns "check network connection". I have two questions:
Has anyone experienced this or had the network board replaced?
Did the P65VT25 come with the wireless adapter or was that an optional accessory?
Chuck
Ckreiter is offline
Old 08-17-2013, 12:10 AM
fatuglyguy's Avatar
Quoted: 285 Post(s)
Liked: 616
I've never replaced the network board in a Panasonic, but I did own a 2010 Panasonic Plasma similar to yours (a G20) and had a similar issue after a couple years. I would press the "Viera Cast" button on the remote and get nothing. The screen would flash for a second like it was going to launch into the app page and then nothing. Since I never used the apps built into the TV much anyway, I never bothered to fix it.
If I recall correctly, no Panasonics came with a wi-fi adapter in 2010 and it was an optional accessory. the appropriate adapter was the DY-WL10. There's also a generic Netgear adapter that works with 2010 Panasonics that should be easier to find...the WNDA3100.
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Audioquest Nighthawk|Audioquest Dragonfly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Sonos Connect|Furman Elite-15 PFi|Sony 43X800D
fatuglyguy is offline
Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv
