IR on my vt60!!!! :( - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-21-2013, 10:44 PM - Thread Starter
fenderhead's Avatar
I passed out while playing Skyrim and it was stuck on the pause menu for over an hour. Now I have part of the HUD stuck on the screen, its really saddening me considering I paid so much for this TV and I feel like I ruined it.... It's very slight, but I can see these lines at the top, the word "quest" and some other skyrim-esque shapes, faint but they are there. Was running it ok THX cinema, 50 contrast, -7 brightness, 50 color, 0 tint, 50 sharpness, and warm2 color temp.pixel orbiter was on so You could imagine my surprise and frustration when I woke up and realized my tv may be ruined. I lowered the contrast to 40, brightness to -10. Is there anything I can do to fix this? frown.gif
fenderhead is offline
post #2 of 10 Old 08-21-2013, 10:52 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
First ting is to run the screen wiper for an hour or so.
vinnie97 is offline
post #3 of 10 Old 08-21-2013, 10:57 PM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 109
Yes there is a way not to do that again DON'T DRINK and play video games at the same time
Phil17108 is offline
post #4 of 10 Old 08-21-2013, 11:00 PM - Thread Starter
fenderhead's Avatar
I actually came home from a long and very early morning shift at work, and just relaxed a little too much I suppose. No drinking involved, just sleep deprivation. I'm just real upset, and freaking out about my tv. Before I bought it I remember reading reviews, and they had said in order to do permanent damage that you'd have to leave an image on for like 13 hours or something crazy. My console shuts off after an hour of being left allne, and TV goes within 15 mins of no signal. Will the screen wipe really work?
post #5 of 10 Old 08-21-2013, 11:10 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
That's why they built it into the settings. You left a static screen in place for under 2 hours, so IR is in all likelihood the worst that has happened. Only when it becomes permanent can it be described as damage or burn-in.
fenderhead likes this.
vinnie97 is offline
post #6 of 10 Old 08-21-2013, 11:15 PM - Thread Starter
fenderhead's Avatar
Okay. I'm going to run the screen wipe for an hour or so, we'll see what happens. Thanks.
post #7 of 10 Old 08-21-2013, 11:53 PM
Oimagination's Avatar
if it was only left on for an hour it should go away pretty quick just by watching normal content.
Oimagination is offline
post #8 of 10 Old 08-21-2013, 11:54 PM - Thread Starter
fenderhead's Avatar
so I can watch a blu ray or Netflix and it should be okay?
post #9 of 10 Old 08-22-2013, 01:27 AM
dingo99's Avatar
A couple things to note:
  1. THX modes turn off pixel orbiting, so I wouldn't recommend them for gaming. You can get just as good a picture using Cinema or Custom modes and not lose pixel orbiting (if you want, try settings from CNET, D-Nice, AVForums, etc. as a starting point).
  2. You might want to go into Skyrim's settings and lower the HUD opacity. Doing so wouldn't help with leaving the pause screen up, but it would reduce the potential IR of the compass at the top of the screen.
dingo99 is offline
post #10 of 10 Old 09-27-2013, 05:33 AM
Quoted: 1679 Post(s)
Liked: 719
fenderhead.
So.......did the IR eventually go away?
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is online now
Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv
