CEC issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-25-2013, 07:27 AM - Thread Starter
rssahlman's Avatar
I have a PN51F8500 and a Yamaha V473 receiver. When I start up the 2 of them The TV will come on and then the receiver after the TV gets started will switch over to Audio rather than staying on the TV setting so I end up with no sound until I switch the receiver back to the correct setting (HDMI 1). I am using the "ARC" HDMI on the TV (HDMI 3) so that when I use the apps I get sound on the return channel and can hear them through my receiver.
If I switch off the "Anynet+ (CEC) then this does not happen....can I resolve this while still using the anynet+ ???
Obviously when I use the apps the receiver needs to switch to the Audio setting in order to hear the apps (such as Netflix) so now I will have to switch that manually if I leave off the CEC. is there a solution?
Thanks in advance
Rick
rssahlman is offline
