PN51F8500 - Service Menu Mistake - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-29-2013, 10:36 AM - Thread Starter
BobCat25's Avatar
I finally upgraded my old faithful Hitachi 51S715 with this new Samsung plasma - My only complaint is that I wish I didn't wait so long to buy this Plasma. I kept reading about these Cal-Day and Cal-Night settings so I got up the nerve and entered the service menu. My dumb a** made a mistake and went into the section that shows HDMI Calibration. It had a check mark next to it and instead of hitting the return button I hit the enter button of course - by accident. The check mark changed to "Wait" and then finally to "Fail". I'm just wondering how badly I screwed things up. I'm happy I didn't brick this TV but I'm still kicking myself for this stupid mistake. I then did a factory reset but the picture does not look as good as before with the same settings. Also, after the factory reset - I went back into the Service Menu and saw that the HDMI Calibration still shows "Fail". I was wondering if Samsung might have a Calibration file that I can upload back into the TV and restore the Calibration. I'll probably try the Remote Management from the Support menu or Samsung directly. Unless anyone might know another way to fix it - I would greatly appreciate any advice on this. Finally, I was able to get the Cal-Day and Cal- Night options afterwards but I'm so pissed I'll probably rip the Mute, 1,8 and 2 buttons out of my remote. There were so many warnings about this too but I just got mixed up between the enter and return buttons.....mad.gif.
BobCat25 is offline
post #2 of 7 Old 08-29-2013, 11:47 AM
willieconway's Avatar
Quoted: 154 Post(s)
Liked: 148
This thread seems to be about your issue: http://www.avsforum.com/t/777497/samsung-calibration-failure
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D. Currently boxed up: Denon 1713, Klipsch SW-450,
NHT Absolute Center, Energy Veritas 5.1s, 5.2C, V-Mini-C.
willieconway is online now
post #3 of 7 Old 08-29-2013, 11:58 AM - Thread Starter
BobCat25's Avatar
I was finally able to find some information on this - it appears I can use a Black and White Checker Board image to recalibrate the HDMI input. Also, It looks like an ISF Calibration could solve this issue as well. I do have a DVE HD Basics disc but I'll have to check if that image is on there. Also, it seems that the Spyder 3 Calibration tool would be a good investment too - I can fix the HDMI and then calibrate the Plasma too. Though I'll still wait to see if anyone can help me with this in the meantime.
BobCat25 is offline
post #4 of 7 Old 08-29-2013, 12:01 PM - Thread Starter
BobCat25's Avatar
Thanks Willie - I was typing my second post when you replied yours.
BobCat25 is offline
post #5 of 7 Old 08-29-2013, 12:23 PM - Thread Starter
BobCat25's Avatar
It's nice to see I'm not the only moron who made this mistake. The only problem now is I'm not sure if that same Black/White Checker Board image is the same one to use on my 51F8500. I do know that the image resolution should be 1920 x 1080.
BobCat25 is offline
post #6 of 7 Old 08-29-2013, 02:24 PM - Thread Starter
BobCat25's Avatar
I finally got the Black and White image on the screen but still get a Fail every time I try to Calibrate. I've tried the 1920 x 1080 file from 480, 780p, 1080i and 1080p with no success. I read on the older Samsung's that there should be a small square that appears on the screen and moves around while calibrating. I never see this small square come up. On a good note, my Samsung just came directly from the factory and it seems the bright whites don't appear to make the Plasma buzz as loudly as the older manufactured ones.
BobCat25 is offline
post #7 of 7 Old 08-29-2013, 03:48 PM - Thread Starter
BobCat25's Avatar
Finally, Success.....I used a different image with just 4 squares. I noticed the other 3 Calibration settings - AV Calibration, Comp Calibration and PC Calibration now have a "/" (Forward Slash) as the status and are all grayed out. Is this normal? I thought they had checkmarks before but I could be wrong. The picture quality seems to be back to normal now. It's amazing how the HD movies appear to have the images pop out of the screen. Thanks again Willie for the information.
BobCat25 is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
