Pioneer elite 141fd recognizing only one hdmi input - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-01-2013, 08:52 PM - Thread Starter
primetime22's Avatar
I have had the tv for three years, had it professionally calibrated and it has always worked flawlessly. I am no video or electronics professional so don't assume it's not user error.
I have had my cable receiver hooked up to input 5 and the ps3 to input 6 (both hdmi). Both have work fine toggling between the two for 3 years. I don't know if I accidentally changed a setting or what, but only input 5 seems to work now. I confirmed its not the ps3 and I also tried other inputs to no avail. The cable receiver works fine if plugged into input 5 and the ps3 works fine if plugged into input 5, but neither works if plugged in inputs 6-8. I feel like there is some setting that was accidentally changed rather than issues with the inputs. If anyone can help it is greatly appreciated. Thank you in advance.
primetime22 is offline
post #2 of 2 Old 04-18-2014, 08:55 PM
Yog
Yog's Avatar
Did you figure this out or still having this issue? My Kuro just started the same behaviour.
Yog is offline
Pioneer Pro 141fd 59 6 Elite Kuro Plasma Panel Widescreen 1080p Fullhd
