URGENT! Is 51f5300 going to stutter??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-06-2013, 08:57 AM - Thread Starter
ultimoamore's Avatar
I just ordered a 51f5300, without noticing it doesn't have 24hz handling.
Is it going to stutter badly on 1080/720 sources???
I use mostly my PC as source.
Damn...
ultimoamore is offline
post #2 of 5 Old 09-06-2013, 12:47 PM
will7046's Avatar
Liked: 34
No,
I have this set
You will be fine, it can handle 24hz content at 60 hz (with 3:2 pulldown being done by the player), at 24hz with cinema smooth off and letting the set do the 3:2 pulldown, or at 24hz with cinema smooth on preserving the correct film like cadence (this is my preference).
will7046 is offline
post #3 of 5 Old 09-06-2013, 01:59 PM - Thread Starter
Hi,
thank you for the reply.
You say you have this set, and that you can turn on/off cinema smooth. As far as I know F5300 doesn't have cinema smooth...
post #4 of 5 Old 09-08-2013, 08:55 AM - Thread Starter
bump....
anyone else?
post #5 of 5 Old 09-09-2013, 12:37 PM
will7046's Avatar
Liked: 34
It has cinema smooth, its not listed in the manual but its there under film mode, trust me i have this set
will7046 is offline
Samsung Pn51f5300 51 Inch Plasma Hdtv
