A bit frustrated...65S64 vs. ST60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-11-2013, 07:46 AM - Thread Starter
edburn3's Avatar
Got my 65S64 from Costco set up a week ago. I do not have many hours on it but so far my picture quality is OK. Maybe I was expecting a bit more. Hopefully, that will improve with age and Fairchilds settings.
My question.......I have 90 days to return to Costco. At this point I do not plan on doing so but if I did I would spend a bit more to get the ST60.
Is their a significant difference in the PQ of the ST60 vs. the S64?
My room is very dark. Only watch movies and TV. No gaming.
Thoughts??
edburn3 is offline
post #2 of 3 Old 09-11-2013, 08:34 AM
Cuda1169's Avatar
Quoted: 24 Post(s)
Liked: 73
CNET gave the ST60 5 stars and its Editors Choice Award. I have the ST50 and my neighbor has the ST60 and they both look great with his ST60 maybe being a little sharper. Apparently the ST60 does have some input lag issues but if you’re not a gamer this shouldn't be a problem. From what I read, I don’t think you can go wrong with either the ST60 or S64. Given you have a 90-day return widow you could give it a couple more weeks before making a change.
Cuda1169 is offline
post #3 of 3 Old 09-11-2013, 10:04 AM
chunon's Avatar
Quoted: 2466 Post(s)
Liked: 2208
What picture settings/mode are you using on your S64 ?
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P50st60 50 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv
