Panasonic P65ST60 vs P60ST60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-13-2013, 07:28 PM - Thread Starter
jackofblades's Avatar
Hi guys, really appreciate your feedback when I have questions. My question tonight is: Would you pay the extra $700 to get the 65" over the 60"? I have 9 foot ceilings and will probably put my sofa about 12 feet away from the TV.
jackofblades is offline
post #2 of 6 Old 09-13-2013, 07:39 PM - Thread Starter
Little update: I can afford the $700 but if the 5" isnt much of a difference I don't want to spend the extra money
post #3 of 6 Old 09-13-2013, 08:08 PM
Bkultra's Avatar
@ 12' viewing distance I would opt for the 65". I have a 60" VT but I only sit 8' from the set
Bkultra is offline
post #4 of 6 Old 09-13-2013, 08:27 PM
shenaniganz08's Avatar
Liked: 53
I'm curious about this too I'm comparing the 60" ST60 vs 65" S64 and right now the st60 seems brighter. but I'm wondering if that's only because the st60 is smaller.
I wish someone could do a direct 60st60 vs 65st60 comparison
shenaniganz08 is offline
post #5 of 6 Old 09-13-2013, 08:40 PM
tubayj's Avatar
65ST60 and don't look back. Just spend the extra if this set will be your main tv.
I sit 10" from my 65S64 and pretty awesome PQ but an extra 5in would've been just right for my room.
I think you'll be happy regardless which size you decide.
tubayj is offline
post #6 of 6 Old 09-13-2013, 08:49 PM
hoosierdsddie's Avatar
I say if you can fork out the extra $700.00 go for the 65". I have yet to hear anybody say they wished they'd bought a smaller tv. I sit 6.5 ft away from a 60ST60 and that is perfect for me. A 60" at 12' would seem pretty far. Plus you need to consider that most movies are letterboxed.
hoosierdsddie is offline
Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv
