Samsung PN60E550D1F no picture, has sound, capacitors look ok - AVS Forum | Home Theater Discussions And Reviews
post #1 of 40 Old 09-16-2013, 06:55 AM - Thread Starter
Robb009's Avatar
My Samsung PN60E550D1F lost it's picture. It still has sound. I took the back panel off and all the capacitors look ok. There are no signs of excessive heat on any of the boards. Is there a way to test the boards to isolate the failed board? I was hoping to just replace a few capacitors, but now I'm stumped. Any advice will be greatly appreciated.
Robb009 is offline
post #2 of 40 Old 09-16-2013, 06:55 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
In a dark room, can you see any glow from the screen?
tom669 is offline
post #3 of 40 Old 09-16-2013, 07:26 AM - Thread Starter
Robb009's Avatar
Thank you for responding. No there is no glow at all. I even put my eye up to it in a dark room and nada. It's just out of warranty and didn't get used that much. Everything looks so nice and perfect on the inside :/
Robb009 is offline
post #4 of 40 Old 09-16-2013, 08:07 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
OK, do you have a digital multimeter available, or can you borrow one? You will need it to diagnose where the fault is.
tom669 is offline
post #5 of 40 Old 09-16-2013, 08:45 AM - Thread Starter
Robb009's Avatar
Yeah, I've got a multimeter & been probing around and finding some voltages on most boards but I don't know what I'm doing or what voltages I should be finding. 5.5v seems rather common. Thanks, again, for responding.
Robb009 is offline
post #6 of 40 Old 09-16-2013, 09:12 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
OK, on the back metal plate of the plasma display panel there is a sticker marked SAMSUNG with VS, VA and other voltages written on it. This is the "panel sticker". Please note the voltages or take a picture of the sticker for me to see. Typical range for Vs and Va on 2012 series Samsung is 205 to 215V and 50V to 58V respectively.
Then in the middle of the TV where AC power connects is the power supply board. There should be test points for Vs and Va on there, among others. Set your DMM on volts DC; if it has separate ranges, select 600V or 1000V. The black probe goes on an exposed part of the chassis and the red probe on the test point. Check the voltage matches the panel sticker within about 2 volts.
tom669 is offline
post #7 of 40 Old 09-16-2013, 09:54 AM - Thread Starter
Robb009's Avatar
Ugh, lost internet.
It's says Vs - 211; Va - 57. On the power board, I'm getting VS-TP - 10v; VA-TP - 0v. The fuse passes an ohm test. I think you're on to something. You're good!
Robb009 is offline
post #8 of 40 Old 09-16-2013, 10:17 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Just to confirm were those voltages measured while the set had audio and would normally have a picture?
Does it spike up at any time or is it permanently measuring around those values?
At this point it is either a power supply fault (unlikely) or a Y-main, X-main or control board fault, reasonably likely.
Can you supply a photo of the overall chassis layout so the Y-main and X-main can be isolated?
tom669 is offline
post #9 of 40 Old 09-16-2013, 10:36 AM - Thread Starter
Robb009's Avatar
Here you go.
Yes, it powered on I heard my ps3 intro sound before I checked voltages and they were steady
I noticed a spark on the large black transistor looking component when I tried to do an ohm reading on the IC in the following
Robb009 is offline
post #10 of 40 Old 09-16-2013, 10:49 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Where is that transistor located?
Try powering the set on with both the top orange and bottom orange large boards disconnected from the power board and from each other. Leave the flat white ribbon on each connected, and leave them connected to their respective buffer/extension boards (green and orange.) Do Vs and Va briefly rise to their rated voltages? (It will shut down due to Y-main/X-main fault detect. No image expected on display.)
tom669 is offline
post #11 of 40 Old 09-16-2013, 11:30 AM - Thread Starter
Robb009's Avatar
Transister like component was on the power supply...I hope I didn't mess it up. The Va & Vs did not rise.
With the x & y boards disconnected, it will not power up & voltage is zero. With x and/or y connected, Vs spikes around 200v & rapidly decreases to 10v while Va spikes around 40 something volts & decreases to zero. I appreciate your assistance and lesson. Thank you.
Robb009 is offline
post #12 of 40 Old 09-16-2013, 01:51 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
OK. Below the power board, and underneath the stand bracket is a small green circuit board. It should have an LED on it. The LED will either blink once a second, indicating normal operation, or it will blink once every 5 seconds, indicating a fault. What does it do?
tom669 is offline
post #13 of 40 Old 09-16-2013, 02:45 PM - Thread Starter
Robb009's Avatar
Once every five seconds. You are a saint!
Robb009 is offline
post #14 of 40 Old 09-16-2013, 02:59 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
OK. In which case, replace both the X-main and Y-main boards.
Once place to buy:
http://www.shopjimmy.com/samsung-bn96-22115a-y-main-board.htm
http://www.shopjimmy.com/samsung-bn96-22114a-x-main-board.htm
You may be able to buy them cheaper elsewhere. Replacing both is recommended due to how the energy recovery circuit chains the two boards together. Failure of one may cause damage to the other.
Check PBA (BN44-xxxxxxxA) matches, as well as REV number.
After doing so, apply all firmware updates available for your model to avoid repeat failure.
If you PM me, I'll send you the Service Fast Track guide for this panel. I can't distribute it here directly, as Samsung don't like that.
tom669 is offline
post #15 of 40 Old 09-16-2013, 03:36 PM - Thread Starter
Robb009's Avatar
Wow, Tom, I wasn't expecting to get through this so easily. Thank you very much for walking me through this problem. I learned a lot today. You and avsforum are awesome! Cheers!
Robb009 is offline
post #16 of 40 Old 09-16-2013, 03:51 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Glad to help. Anything saved from landfill is a victory. Please reply back if the problem is fixed for future reference.
tom669 is offline
post #17 of 40 Old 06-28-2014, 06:40 AM
Liked: 0
Fixed?????
Hello, Robb009 did you ever get the tv fixed.... which board was the problem... Thanks..
hooptydude95 is offline
post #18 of 40 Old 06-28-2014, 04:03 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
I believe it was eventually determined that the panel was cracked and this was causing his fault.
tom669 is offline
post #19 of 40 Old 06-28-2014, 04:58 PM
Liked: 0
i like that,Copy:This is the "panel sticker". Please note the voltages or take a picture of the sticker for me to see. [IMG]http://*******/njkHuk[/IMG]Typical range for Vs and Va on 2012 series Samsung is 205 to 215V and 50V to 58V respectively.
onetwosrecv is offline
post #20 of 40 Old 07-22-2014, 09:31 AM
Liked: 3
I have nearly the exact same problem on my PN60E550, except mine usually (7/10 times) will turn on and work correctly. When it doesn't turn on, I get the exact same symptoms; no picture(or glow) and sound only. I imagine I probably have a a bad cap somewhere. Would this problem also point towards the X and Y boards? Thanks for any input,
Mark
mprowland is offline
post #21 of 40 Old 07-24-2014, 05:11 PM
itsloud's Avatar
Mine is doing the same thing. Cold start, always works. If it's been on for a while, then you turn if off, try to turn it back on within say 30 minutes, no picture. I get sound, no glow.
itsloud is offline
post #22 of 40 Old 07-26-2014, 10:37 AM
Liked: 0
Having same issue with PN60E530 model for about a month. Went from taking 2 or 3 on/off attempts to get a picture to dozens. Once it's on it's perfect but it's at a point where I'm sure I'm going to do more damage with all the attempts.
Repairman came and tested today and feels it's either the Y sustain board or the panel. The Y board showed no shorts but when driver was connected it lost power and when disconnected everything else tested fine and showed no drops on meter. Basically the only issue seems to be when that Y board is connected so he's suggesting ordering one and trying out since it's an easy replacement. If that doesn't work then return it but it's likely then a panel issue and that will mean scrapping which I'm really hoping isn't the case since I'll have basically just paid a grand for 18 months of service.
I'd give more testing details but I'm unable to explain myself since I just have a basic understanding of what his findings were. It's two ribbon cables and screw mounts so the board is a simple replacement so I'll try and report back results if that helps anyone.
grekel is offline
post #23 of 40 Old 10-16-2014, 09:53 AM
Liked: 0
Samsung PN60E550D / Picture won't turn on - same problem as the rest
TV continually getting worse - once it's on - it's perfect. Volume will still work but no picture. Of course - just out of warranty - 3 payments left. REALLY SAMSUNG? $1500 plus TV should work longer than the warranty. Samsung repair wants $150 just to walk thru my door. Will never buy another Samsung product - they know this set has this problem and should have recalled the part at least. Any good honest TV repair guys on the Treasure Coast of FL?
CMCKENZIEFL is offline
post #24 of 40 Old 10-16-2014, 10:36 AM
sumguy91's Avatar
Quoted: 96 Post(s)
Liked: 34
You say you're making payments for this TV? Is this payment plan via your credit card? If you're paying using AMEX, Discover, Visa or Mastercard, then you should know that they have an extended warranty that's good for the year after your original manufacturer's warranty expires. If the above applies to you, then call your credit card company and file a warranty claim.
sumguy91 is offline
post #25 of 40 Old 10-25-2014, 03:05 PM
Liked: 0
Great help in this thread!
thisisme08 is offline
post #26 of 40 Old 10-27-2014, 05:23 PM
itsloud's Avatar
Replaced the Y-Main on mine today, works like a champ again. Still pissed at 1.5 years old this happens and Samsung refuses to take ownership of an issue that many are having with the sets.
itsloud is offline
post #27 of 40 Old 10-28-2014, 05:44 PM
Liked: 0
In need of a good repair guy
Hhgregg credit - no interest for 18 months - wish I would have purchased via credit card now.
Anybody know of a good TV repair guy on the Treasure coast of FL??
post #28 of 40 Old 01-18-2015, 07:23 PM
Liked: 0
Having the same issue with my 60' Plasma PN60E550
Reading this thread, it appears the Y-Main Board needs replacing? Do I just need to follow the same steps to rule out?
Mine turns on only after being off for at least 30 min. Otherwise I just get sound.
Jeremy Andrew Davis is offline
post #29 of 40 Old 02-03-2015, 03:06 PM
Liked: 0
I had the same issue on a couple of PN60E530 models, still awaiting replacement controller ICs for further testing but thread number 43075 over at the Badcaps forum may be of interest. Sorry I can't post a direct link as I'm a new member.
The issue here is with the -Vscan supply, seemingly the ICE3BR0665J PWM controller IC iteself.
d_russell is offline
post #30 of 40 Old 05-05-2015, 05:38 PM
endi's Avatar
Pn60e530(a3f)
Tom, I am unable to PM you due to my <15 posts.
I followed your advice to user Rob009 regarding his Samsung TV with Sound but no Video. I am experiencing the same. When I have the Y board disconnected Vs spiked to 210V and drops to 0; when everything is plugged in it's 9-10V. When both are unplugged there is 0V. Also the LED at the base-mount is flashing every 5s.
I would like to do the next step and replace the X and Y Boards and I was wondering if you could send me the guide that you mentioned in your post. I would very much like the best shot of doing this correctly! Also unless it's in the guide, how do you update the firmware on a television? It has a USB stick in the back can that be used to hold the firmware file and somehow instruct the TV to grab and install it?
I would appreciate any advice or guidance. Additionally, the YBoard at shopjimmy is out of stock so I'll be looking around elsewhere. If you have another supplier that you trust I wouldn't mind a link
Thanks again so much for the steps and instruction; I was quite disappointed this television failed this way so soon and now I have hope that I may repair it
andrej
endi is offline
Samsung Pn60e550 Plasma Hdtv
