60" F8500 or 65" ST60 at the same price? - AVS Forum | Home Theater Discussions And Reviews
Old 09-22-2013, 01:50 AM - Thread Starter
qpvh79's Avatar
This has been torturing me for a couple weeks. I can either get a 60" Samsung F8500, or, for $50 less, a 65" Panasonic ST60. I'm upgrading from a 36" 480i CRT, so I'm sure that either unit will flat out amaze me, but that's not making the decision making process any easier.
Unfortunately, the store only has an ST60 on display, which looks pretty good despite the minor image retention. The auto brightness control was also very noticeable. I've read that the F8500 is brighter and doesn't suffer from as much IR and ABL, but also has fairly limited vertical viewing angles. Just wish I could see one in action!
I can easily control room brightness, don't care at all about 3D performance, and will be sitting around 9 feet away from the TV.
To those who've seen both, which one would you pick?
qpvh79 is offline
Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv
