HELP------- Trying to find a plasma display around 42" that you won't want to throw rocks at. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-25-2013, 09:45 AM - Thread Starter
Quoted: 1393 Post(s)
Liked: 587
For the last few months, I've been looking off and on for a 42" (or thereabouts) display to go into my bedroom.
Now a good friend of mine called and wants me to advise him of a 42" display.
In looking around, the only 42" plasmas that I've found look pretty bad. Nothing that I'd want much less recommend to someone else.
Does anyone know of a 42" ish plasma that looks pretty good from one of the top tier companies? Don't want junk as I'll catch the heat for recommending it.
Both applications are for bedroom use so we're talking fairly dim lighting.
I'm just wondering if the age of 42" plasmas have past and I'm going to have to settle on an LED???
HELP
JimP is online now
post #2 of 10 Old 09-25-2013, 10:13 AM
PlasmaPZ80U's Avatar
Quoted: 1966 Post(s)
Liked: 560
HELP
there was the TC-P42S60, which was discontinued some months ago
perhaps in 2014, another 42" 1080p model from Panasonic will be available
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #3 of 10 Old 09-25-2013, 10:23 AM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
For a dark bedroom plasma without a doubt.For bright rooms you can justify a led LCD.
Vic12345 is offline
post #4 of 10 Old 09-25-2013, 11:11 AM
loopguru's Avatar
I have the 43 inch version of the set detailed in this article and am very happy with it
http://thewirecutter.com/reviews/the-best-500-tv/
loopguru is offline
post #5 of 10 Old 09-25-2013, 11:35 AM - Thread Starter
Liked: 587
Looks interesting. Only objection is that peak white measure at 41 foot lamberts which for most is enough for dim room. I'd want it a tad brighter but this might be as good as it currently gets.
Thanks for posting.
JimP is online now
post #6 of 10 Old 09-25-2013, 11:58 AM
Liked: 560
don't the current Samsungs have floating blacks?
post #7 of 10 Old 09-25-2013, 12:10 PM
loopguru's Avatar
I'm not sure what that means, but the blacks on my set are pretty darn solid. I doubt if John Turturro's hair is much if any blacker on much more expensive options. My only issues really are the reflective screen and the lack of analog audio out, and both have been dealt with by the application of money .. (curtains and an optical to analog converter)
loopguru is offline
post #8 of 10 Old 09-26-2013, 09:29 AM
Liked: 560
floating blacks are when the black level rises significantly as the average brightness of the scene goes up (aka "APL", average picture level)
the F8500 has been confirmed to do this.... with really high APL content it can make the black level go up to .02 fL
you won't see any effects of this in dark scenes though, as they are low APL
post #9 of 10 Old 09-26-2013, 10:33 AM
improwise's Avatar
Is this still true? From what I've heard, it used to be the case but a few firmware upgrades have at least made the problem less obvious. I have the F8500 myself and can't say that I've seen it myself, but of course the much higher brightness of the F8500 compared to the Panasonics probably makes the black levels look better to the eye than perhaps it is. That said, I still consider the Panasoncis to have slightly better blacks than the F8500, no question about it.
improwise is offline
post #10 of 10 Old 09-27-2013, 04:49 PM
Liked: 560
with a light meter and some DVD/BD test patterns, you could check this yourself
how noticeable this is is debatable since high APL scenes will make the blacks look darker than they really are (an illusion based on how our eyes work), so the difference might be more subtle than the measurements suggest... I've never had the chance to study this behavior myself though and I'm referring to what the user zoyd (and buzzard) has posted in the calibration forum
Panasonic 42 Inch Plasma Hdtv Tc P42s60 , Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
