Stumped - TV repaired and now 3D glasses won't sync? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-26-2013, 01:02 PM - Thread Starter
Screaming's Avatar
My TV is a Panasonic TC-P50UT50. The 3D glasses I have for it are model TY-ER3D4MU.
I bought the TV 14 months ago. A week ago, the TV stopped working. It wouldn't turn on. I have an extended warranty through the store I bought it, so I called them. The red light on the TV would blink 8 times. The repair company ordered a replacement power board and replaced it. It works fine now, except...
I can't get my 3D glasses to sync with it. I have two pairs. We used them maybe 1 month ago and they both worked fine. Now neither pair will sync. They just flash green and red. The store says that my TV works so this isn't covered under the warranty and to contact Panasonic. I did that. They had me try a number of things and still nothing.
Do any of you have any idea? I know they work using bluetooth but I can't figure out how to test to see if that's working on my TV.
Screaming is offline
post #2 of 4 Old 09-26-2013, 06:27 PM
loopguru's Avatar
What were the things they had you try?
loopguru is offline
post #3 of 4 Old 09-26-2013, 08:03 PM - Thread Starter
Screaming's Avatar
Mostly sliding the button to mode and holding it there for various lengths of time. She also had me reset the tv by holding the volume button on the tv and holding a button on the remote. None of that solved the problem.
I did that again this evening and the first screen is the "self check" screen and it has everything listed as OK except for BT which has a red "01" after it. From another panasonic tv's manual that I found, that means there's an absence of bluetooth. So I called Panasonic again and the guy had no clue about the 01.
post #4 of 4 Old 09-26-2013, 08:24 PM
fatuglyguy's Avatar
Quoted: 283 Post(s)
Liked: 609
perhaps the tech disconnected/messed with your TV's bluetooth receiver accidentally when opening it up? The bluetooth module is housed and labeled in a little compartment towards the lower right or left hand side on my VT50.
In any case, I doubt both your pairs of glasses would stop working suddenly. Don't see why this wouldn't be covered under your warranty.
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Audioquest Nighthawk|Audioquest Dragonfly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Pro-Ject Debut Carbon DC Esprit + Tube Box S|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is online now
Panasonic Viera Tc P50ut50 50 Inch Plasma Tv , Panasonic Viera Ty Er3d4mu Active Shutter 3d Eyewear , Mitsubishi 3dgx103 Xpand 3d Glass Black
