Blur on my TCP50S60? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-26-2013, 11:13 PM - Thread Starter
dagens24's Avatar
Hi all; new the the forum and plasma televisions; I just had a quick question. I bought a TCP50S60 two weeks ago and I've noticed a lot of blur when playing games. Whenever I rotate my camera or objects move around my character I see a double vision effect (for lack of a better word), almost like ghosting. I've recorded a video of it.
http://www.youtube.com/watch?v=t-sbWqjBU9M
If you look at the icon they seem to ghost quite badly as I move the map. Is this normal, or is my set faulty somehow? Thanks for any input.
Oh, also, I notice subtle off-white horizontal lines when white images are on screen. Is that to be expected? Thanks.
bskubs likes this.
dagens24 is offline
post #2 of 3 Old 09-27-2013, 04:02 AM
curly21029's Avatar
Liked: 34
I believe what you're actually seeing is phosphor trailing. Having bright/white objects juxtaposed with dark/black ones during fast movement/pans is the easiest way to detect it. In addition, the effect is seemingly exacerbated by 30fps -- the standard for current-generation games.
Resolution: stop looking for "defects" (i.e. intentionally reproducing the issue) and just enjoy your television. smile.gif
curly21029 is offline
post #3 of 3 Old 09-27-2013, 09:03 AM - Thread Starter
dagens24's Avatar
Hey, thanks for identifying what I was seeing.
dagens24 is offline
Xbox 360 Elite 120 Gb Console System
