Vizio VP322 NO AUDIO - AVS Forum | Home Theater Discussions And Reviews
Old 10-01-2013, 06:30 PM - Thread Starter
Unicornio6969's Avatar
Hi guys I really need you help, the problem with my Vizio tv is that has no Audio at all.I even replace all the caps from the power supply that goes bad most of  the time and I also bought the small audio board thinking that will fix my  problem but no luck.Please if someone call help me fix my problem I will appreciate..o any suggestions?  Thank You
This is the part number of the small audio board that I bought 0171-2871-0320 ...
Unicornio6969 is offline
Old 10-23-2013, 07:27 PM - Thread Starter
Well since nobody help on this issue I decide to buy the Main Board and that fix my problem..The Main Board is the one where it has all the HDMI conections and audio inputs..So if someone has this problem I hope this can help them..
