Magic Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-02-2013, 08:10 PM - Thread Starter
Kizzer's Avatar
Hate it.
Is there a standard LG model to replace this? I really do not want a "universal" remote.
Kizzer is offline
post #2 of 5 Old 10-04-2013, 11:45 AM - Thread Starter
Kizzer's Avatar
I guess not
Kizzer is offline
post #3 of 5 Old 10-05-2013, 09:42 AM - Thread Starter
Kizzer's Avatar
Is there an LG forum somewhere on the interwebs to actually get questions answered?
Kizzer is offline
post #4 of 5 Old 10-06-2013, 03:28 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 521 Post(s)
Liked: 776
Your thread title is too vague. You should put your question in the title so people know what you're asking about.
You might want to contact LG and ask them if one of their standard or OEM remotes operate your TV.
You can also try the Remote Control forum here on AVS, and also try RemoteCentral.com too.
Philips makes a great little inexpensive universal learning remote - i got the Rite Aid drugstore version for $14 as a secondary remote to keep on a desk in the far corner of the room and it capably operates my TV, AVR, Tivo, TWC DVR, and DVD player. You could try it then if it doesn't operate the TV, return it.
http://www.usa.philips.com/c/home-entertainment-accessories/perfect-replacement-7-in-1-sru5107_27/prd/en/;jsessionid=8D5366799BC43B3E07447DD09E7A61CF.app120-drp2
Kizzer likes this.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 5 Old 10-06-2013, 05:29 PM - Thread Starter
Kizzer's Avatar
Thanks for all the advice, I appreciate it. I'll check those sites you mentioned.
Kizzer is offline
