Wake-Up Alarm - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-03-2013, 04:26 AM - Thread Starter
the3man's Avatar
Let me say it's been awhile since I've bought a TV for the Master Bedroom and the last one I bought was a Sony KDS-R50XBR1. Even back then it was getting harder to find televisions with "wake-up" alarms and visiting the big box stores to see what's now available has been unsuccessful.
I'm basically a Sony fan, I do like Samsung screens, I'm partial towards LCD's, would like something in the 50-60" range, but at this point I'll take almost anything with a decent screen.
Any recommendations? Thanks in advance.
the3man is offline
post #2 of 4 Old 10-03-2013, 07:50 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
The Panasonic Plasmas have several On/Off timers that you can set to turn the TV on. You can set one for say 5am Mon-Fri, then set one for 7am on Sat, and set one for 9am on Sun. You can also set one to turn the TV off at night if you tend to fall asleep with it on. The most popular Panasonic is the ST60 series and is available in 50", 55", and 60" (as is the lower-end S60 series).
I don't know if the Samsung plasmas have timers like this.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 4 Old 10-04-2013, 07:35 AM - Thread Starter
the3man's Avatar
Thanks Randy, Looks like most of Panasonic's Plasma and LCD line has the timers I need.
Thanks, again!!!
the3man is offline
post #4 of 4 Old 10-14-2013, 04:22 PM - Thread Starter
the3man's Avatar
Thanks everyone. I ended-up with a Samsung 51F8500.
the3man is offline
Sony Kds R50xbr1 Replacement Rear Projection Tv Lamp Xl 5100 93087600 , Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
