Help - 65St60 -Continue to get TV show audio through my receiver when I run Netflix - AVS Forum | Home Theater Discussions And Reviews
Old 10-03-2013, 09:13 PM - Thread Starter
hondo164's Avatar
I set up my 65st60 to my Yamaha RX-v661and have it running through an HDMI switch because I have 3 devices and only 2 HDMI outputs from the receiver. The tV works fine but when I put on Netflix, the sound from the TV show continues while the Netflix is playing. If I turn off the Direct TV DVR or turn down the receiver sound the audio comes through the TV speakers. I can't figure out what is going on any help would be appreciated. Thanks
hondo164 is offline
Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv
