How to Get A Brighter Picture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-07-2013, 09:15 PM - Thread Starter
sammy12's Avatar
Have tried just about everyones calibration for 55st60 including a calibration by I ISF certified tech but picture seems too dark. Any setting people could suggest to get picture brighter I'm at warm 1 and gamma 2.4 with contrast 83. Moving brightness to 26 doesn't do much....thanks sammy
sammy12 is offline
post #2 of 6 Old 10-08-2013, 04:14 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
Is the room dark, if not darken it and if it is, go back to factory defaults.
Phil17108 is offline
post #3 of 6 Old 10-08-2013, 04:36 AM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Most peoples brightness is in the 40s and higher contrast
Vic12345 is offline
post #4 of 6 Old 10-08-2013, 05:47 AM
chunon's Avatar
Quoted: 2013 Post(s)
Liked: 1774
You do realize the brightness control is used to set black level ? Has nothing to do with light output, that would be the contrast control.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #5 of 6 Old 10-08-2013, 03:39 PM - Thread Starter
sammy12's Avatar
Sorry I'm no expert but if the fellows above are saying increase brightness which as you say sets black level wouldn't i get a brighter picture. Don't want an argument just a means of getting my picture brighter. The room is not that bright , I would say about 1/2 to 2/3 as bright as an office when blinds drawn when sun shines directly in for a couple hours but normally during day 1/2 as bright as office,. The other point is the blues are really strong and does that cause darkness.. thanks eveyrbody for suggestions, keep them coming.....sammy
sammy12 is offline
post #6 of 6 Old 10-08-2013, 03:54 PM
hungro's Avatar
Quoted: 164 Post(s)
Liked: 111
It won't get brighter, Brightness affects the darker end of the signal , black levels and shadows will become elevated if the brightness aka black level is set too high. The opposite is true if the brightness setting is set to low.
The picture or contrast setting is what affects your "brightness" overall light output of the picture. The brightness control is not correctly named it should be called, black level. Hope that clears the confusion. Wish they would change this ....manufacturer's are you listening..!!
hungro is offline
Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv
