Is 5,000 hours a lot for a Kuro? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-08-2013, 12:06 PM - Thread Starter
jlove222's Avatar
My KRP600M just hit 5,000 hours, and I was wondering if this is considered a lot? Do you think the picture quality has degraded any by now? Or will this not happen with Kuros? I had it ISF calibrated right when I originally got it. Does it need to be recalibrated or is calibration something that only has to be done once?
jlove222 is offline
post #2 of 6 Old 10-08-2013, 12:15 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
1) The Kuros have something like a 60,000-hour half-life (when the panel dims to half of its original brightness).
2) If you are still wowed by the picture, it is probably not degraded (some have been known to have a red tint develop and/or rising black levels, but these are in the minority).
3) Calibration touch-ups are needed for any panel as it ages (if you want to maintain the original accurate calibration values).
vinnie97 is offline
post #3 of 6 Old 10-08-2013, 06:21 PM - Thread Starter
jlove222's Avatar
I am not quite as wowed as I was when I originally got it, but that might just be because I'm used to it. The black do seem like they might be slightly brighter. :( I'm hoping after a re-calibration, it will bring new life to the display. At 5,000 hours, that will mean it only lost about 5% of its brightness. That should be nothing to worry about, especially considering when properly calibrated the display won't be super bright like they are in the stores, so it really shouldn't be anything to worry about, right?
jlove222 is offline
post #4 of 6 Old 10-08-2013, 08:24 PM
Sloppy Joe's Avatar
5,000 is just broken in!!! lol
Straybeat likes this.
Sloppy Joe is offline
post #5 of 6 Old 10-09-2013, 02:09 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Yes, a touch-up should get those black levels back in shape. I would recommend getting D-Nice out to calibrate, as he has the software and means to achieve unheard of blacks from the Kuros. wink.gif
vinnie97 is offline
post #6 of 6 Old 10-09-2013, 03:12 PM
somelogin's Avatar
It's not really that bad for a tv of that age. Or, well, compared to what from that age COULD be. For instance I have a tv that I bought probably 1-2 years before the 9g kuros came out and I recently looked in the service menu and saw it's only like a day of hours from 25,000.
somelogin is offline
