ZT60 or VT60 for my setup (pic) please help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-08-2013, 09:38 PM - Thread Starter
jsev316's Avatar
Hey everyone, I'm just about to move to a new place and am planning on buying a 65 inch zt60 or vt60 for my new place. Now, it's my understanding that really the only difference between the two sets is the filter on the zt60 helping diminish reflections making it better for bright rooms. I need your advice on which set to get given the room. As you can see in the pic below, I plan on putting the tv in either of those two spots. The room itself, has zero lights, the only light source is from the outside as pictured.
So I have two questions:
1. Where do you recommend I put the tv? The corner or against the flat wall? In either place, there are zero windows opposite of the tv so I won't have to worry about reflections. My only concern is the light from the outside as pictured, will it be a problem in either tv spot? And if it isn't a problem, does this make the filter on the zt60 one that I don't need to spend the extra money for and thus, I should go for the vt60?
jsev316 is offline
post #2 of 2 Old 10-11-2013, 05:37 PM
roncruiser's Avatar
I would put it against the wall. Not in the corner. The window is distracting to me during viewing. I'm partial to the ZT since I just purchased one. If you go VT, you can control ambient lighting with the window shades.
roncruiser is offline
Panasonic Viera Tc P60zt60 60 Inch Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv
