How much buzzing is acceptable on a panasonic s60 - AVS Forum | Home Theater Discussions And Reviews
Old 10-10-2013, 01:46 PM - Thread Starter
vlVlv's Avatar
I have a 65S60 and I can hear a loud buzz from about 10 feet away.  When I put my head behind the pannel, I can hear the buzz in each corners.  It's loud enough to be heard in quiet scenes.  The intensity of the buzz is different from scene to scene.  I know every plasmas will buzz, but how much buzzing is acceptable?
vlVlv is offline
Old 10-10-2013, 01:58 PM
Bkultra's Avatar
I think only you can answer that. If you find it unacceptable then exchange or return the TV. Everyone is different and what is acceptable to one might not be for another.
Bkultra is offline
Old 10-10-2013, 02:06 PM - Thread Starter
vlVlv's Avatar
I'm just trying to figure out if it's normal for this TV or not...
vlVlv is offline
Old 10-10-2013, 04:58 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
You should only hear it up close to the set in a quiet room.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
Old 10-10-2013, 06:54 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
You should not be able to hear any buzzing at 10 feet away. Three of my four Panny's are virtually silent at 2 feet even on a bright or all white screen. Your must have a defective component inside - the two biggest offenders are a buzzing coil on one of the boards in the upper corners, and the other is the power supply near where the power cord connects.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 10-10-2013, 10:06 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
Based on one S60 and two ST60's I've had in my home, plus all the many questions just like yours I've read and replied to, APL-dependent buzzing audible from 10 feet in a quiet room is perfectly normal for these sets, and exchanging sets in hopes of getting a quiet one is futile. Here are a couple of my standard replies on the subject from just a few days ago. The first one gives examples of material and conditions under which you'll hear the buzz, and the second one talks about proper management of expectations:
http://www.avsforum.com/t/1461177/official-panasonic-s60-series-discussion-thread/4350#post_23809184
http://www.avsforum.com/t/1461177/official-panasonic-s60-series-discussion-thread/4440#post_23819313
sawfish is offline
Old 10-11-2013, 01:17 PM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
it has a lot to do with your ears and the room the TV is placed in/viewing distance and ambient noise/sound levels
I can hear high frequency sounds easily and I tend to pick up on distracting sounds like plasma buzzing at times... other times when I am lost in a movie, tv show, or game I don't hear it much or at all
it's kind of like having a analog clock ticking in your room... sometimes you can hear it ticking clearly and loudly (distractingly) and other times you forget it's even there
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
Old 10-11-2013, 01:42 PM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
Yes, it has to do with individual hearing ability, ambient room noise, room acoustics (type of walls, ceilings, rugs, etc.) and the positioning of the set relative to where one is sitting. All these factors can vary dramatically from person to person.
RWetmore is offline
Old 10-11-2013, 01:43 PM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
Originally Posted by PlasmaPZ80U View Post
I can hear high frequency sounds easily and I tend to pick up on distracting sounds like plasma buzzing at times... other times when I am lost in a movie, tv show, or game I don't hear it much or at all.
I'm the same way.
RWetmore is offline
Panasonic 60 Inch Plasma Hdtv Tc P60s60
