Need help deciding.... Panny TC-P60S60 vs Sharp Aquos LC-60LE650U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-12-2013, 06:10 PM - Thread Starter
aceniza's Avatar
Just as the title states.... Currently have a 42" 720p Panny plasma in the master bedroom, and a TC-P50s1 in the living room. Well, the 50" shut down today, got the blinking power LED, now LED won't turn on. Plan is to replace it, repair it, and move it upstairs... but in the mean time...
Do I stick with Panasonic? is the Sharp even worth looking at?
I have a very tight budget of about $1000, and I will not do LG... not sure if VIZIO is any good but I know they weren't back when I was shopping for my first TV...
aceniza is offline
post #2 of 11 Old 10-12-2013, 07:42 PM - Thread Starter
aceniza's Avatar
ok now I'm looking at the 65" s60 vs. the 70" Sharp... same models
aceniza is offline
post #3 of 11 Old 10-13-2013, 10:37 AM - Thread Starter
aceniza's Avatar
beuller?
aceniza is offline
post #4 of 11 Old 10-13-2013, 10:56 AM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 560
go for the S60, it's a better all-around set assuming you room doesn't have bright direct sunlight hitting the TV screen... in a dim to dark room, the S60 has better PQ than most LED-LCDs on the market today (especially in the $1,000 and less category)
it will also do well in a room with moderate lighting as long as the light isn't hitting the screen directly (since the screen is very reflective and lacks the AR filter that the S64 and ST60 have)
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #5 of 11 Old 10-13-2013, 10:57 AM
Latinoheat's Avatar
Quoted: 1088 Post(s)
Liked: 830
Having owned a Sharp Aquos before and now a Panasonic plasma, I would go for the Panasonic. Although the Sharp had a nice picture , it could not compete with the motion and blacks of the Panasonic. With the LCD you will have motion blur specially being a 70" and your angle viewing will not be very good and in a at night time, you will have clouding and flash lighting. Hope this helps a bit.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #6 of 11 Old 10-13-2013, 11:53 AM - Thread Starter
aceniza's Avatar
our lighting actually does hit the screen directly - an annoyance with our current s1
BUT - we will likely be moving in Feb, and even then, different mountings, angles, might help.
My only complaint thus far is our s1 went kaput yesterday after just 4 years. I need a new A-board, which is sold out EVERYWHERE!
aceniza is offline
post #7 of 11 Old 10-13-2013, 12:58 PM
Liked: 560
if you can still get your hands on a S64 (S60 with AR filter), get that
if not, the S60 will be a great TV if you can control the lighting in your room a bit better
post #8 of 11 Old 10-13-2013, 02:30 PM - Thread Starter
aceniza's Avatar
unfortunately I can't find the s64... i already checked
aceniza is offline
post #9 of 11 Old 10-14-2013, 07:30 PM - Thread Starter
aceniza's Avatar
ok... i also saw a sony kld70r550...might be the "a" for $2k otd... whats the opinion on that set?
aceniza is offline
post #10 of 11 Old 10-19-2013, 03:24 PM - Thread Starter
aceniza's Avatar
well i went way off and ended up getting a samsung 65f6300. wanted the 6400 but $200 for features i would literally never use told me no lol
aceniza is offline
post #11 of 11 Old 10-19-2013, 09:39 PM - Thread Starter
aceniza's Avatar
well that didnt last long. went back in and changed the order to the f6400
Armand
Sent from my Apple Galaxy Note 7
aceniza is offline
Panasonic 60 Inch Plasma Hdtv Tc P60s60 , Sharp Lc 60le650u 60 Inch Aquos Led Tv
