HELP - What now? - AVS Forum | Home Theater Discussions And Reviews
Old 10-16-2013, 01:21 PM - Thread Starter
vlVlv's Avatar
I bought a 65S60 and the buzzing was annoying.  I could hear it quite often.  The store brought me another pannel and it seems to be doing the same thing.
Now, is it just two bad pannels, or is it just me who is too sensitive to the buzzing sound of a plasma?  I am at about 10 feet from the screen, in a room where I can hear the air exchanger a bit.
I was wondering if I should go for the ST60...but will I have the same problem?  Will it buzz just like the S60?
vlVlv is offline
Old 10-16-2013, 01:26 PM
Bkultra's Avatar
What altitude do you live at? You should not be able to hear it from 10' under normal circumstances. All Plasmas buzz but you have to be with in a few feet to hear it and it should be more noticeable during bright scenes.
Bkultra is offline
Panasonic Tc P65s60 65 Inch 1080p 600hz Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv
taboola here
