Panasonic TH-50PX75U (Manufactured April 2007)--NOT TURNING ON and NO BLINKING LIGHTS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-17-2013, 12:00 PM - Thread Starter
TV worked fine last night and early this morning then hubby turned it off before leaving for work. Now it won't turn on at all, no blinking lights, not even a single red light, no sounds, nothing.  Manually turned on tv in case it's a remote control problem but nothing.  Also checked the power bar and light is on (also turned this switch off and on and still nothing).  What could be the problem?  Expensive fix?  Thank you.
Mlelv is offline
Panasonic Th 50px75u 50 Inch 720p Plasma Hdtv
