Delivery Checklist for Panasonic TC-P60VT60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-21-2013, 05:14 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Here is what I've picked up scattered around in various threads but did not see in any one concise location so I am posting it here.
  1. Verify that all items are in the box
  2. Verify that there is no physical damage
  3. Connect all connections (at least Power, an HDMI source and ethernet)
  4. Check the screen with a flashlight (to see if there is any cracks or imperfections)
  5. Go to Menu > Help > Version > Status4 to check the hours (number after letters indicates the hours)
  6. Go to Menu > Picture > Screen Settings > Screen Wipe and run a screen wipe to look for dead pixels, blobs or other imperfections
  7. Run the color slide show to verify that the colors are accurate and to continue to look for dead pixels, blobs or other imperfections. Instructions for running a slide show from an SD or USB flash memory are found on page 99 of the eHelp manual previously printed out. Have flash memory ready to go
  8. Listen for excessive fan noise and verify build date for the possible in-factory application of the "foam fix"
  9. Listen for panel "buzzing"
Okay that is it from what I have seen by reading these forums over the past week. Did I miss anything?
Spock1234 and gcannon0317 like this.
Sammy2 is offline
post #2 of 8 Old 10-21-2013, 08:29 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Depending on who you buy the TV from and what level of delivery service they're providing (Curbside, Threshold, Enhanced, or White Glove), you may not be able to or allowed to do all the items above.
I just got an ST60 from Amazon a few days ago with Enhanced Delivery (they don't offer White Glove) and the guys were pretty patient with me even though they were running behind, but they are not required to wait while you do anything above and beyond what's listed in their delivery terms. I was unfamiliar with the redesigned 2013 remote and couldn't figure out how to bring up the USB slides (it's a much different method than on my 2012 GT50). The button is labeled SD/USB and is in the bottom right corner of the remote.
If you don't like the build date or the TV doesn't have the "foam fix" that is not a valid reason for refusing the TV. It has to be damaged or defective in order to refuse it.
Oh and the flashlight is not to find "delaminated layers", it's to check for small spider cracks in the outer screen or inner panel. Check every square inch of the screen, especially at the corners.
Also have the room totally silent so you can listen for excessive buzzing, especially if you're able to display the bright colored slides while the driver is there. If you can hear any buzzing beyond a foot or two away then there's something wrong with the TV. My ST60 is virtually silent unless i put my ear behind the TV, as was my GT50 and G10 and 11 out of 12 Plasmas i've set up for friends/family/neighbors/customers. One friend's 60ST30 buzzed right out of the box and even the delivery drivers said "that's not normal" so we boxed it back up and they took it back. The replacement TV delivered the following weekend was silent.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 8 Old 10-21-2013, 12:59 PM
absurd_username's Avatar
I'm taking delivery of my 60VT60 hopefully this Wednesday morning. However, I won't be taking delivery in my home in Canada but at a receiving service in the US and then bring it back home in a minivan. The inspection will be done somewhere in their office or possibly in their storage trailer. Hardly ideal, but it is what it is when trying to save a few bucks.
After I open up the box, will I need to set the TV up on it's stand or can I leave the set in the bottom portion of the box as a temporary stand while I do the power up and inspection?
At first power up will there be a bunch of setup items to jump through, or can I immediately go into menu with the remote and run a couple of slides and the sweeper?
When I pop the box back onto the TV I'm figuring I'll need to tape/rope it back together to securely carry it, correct?
absurd_username is offline
post #4 of 8 Old 10-21-2013, 01:11 PM
gcannon0317's Avatar
  4. Check the screen with a flashlight (to see if there is any delaminated layers?)
Thanks Sammy2! I receive my VT60 this Friday. Perfect timing.
gcannon0317 is offline
post #5 of 8 Old 10-21-2013, 01:19 PM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1772
Wouldn't number 4 include looking for micro-cracks scratches etc, nice job on the checklist smile.gif
Also listen for buzzing
Sammy2 likes this.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #6 of 8 Old 10-23-2013, 11:17 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
My TV is going to be delivered today. So this checklist (I modified the original post) is pretty much what to look for upon delivery then?
Sammy2 is offline
post #7 of 8 Old 10-23-2013, 11:21 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
All good questions. I'm going to just have mine on the floor in another room until I run the break in slides for a few days. Then I will move it into the family/theater room. Eventually it is going on the wall.
Sammy2 is offline
post #8 of 8 Old 10-24-2013, 09:07 AM
sooke's Avatar
Quoted: 99 Post(s)
Liked: 69
You shouldn't need the stand. My ZT60 stood in the box in a styrofoam base. However, the IR sensor is on the bottom bezel edge (just left of center) so the packing styrofoam might be in the way making the remote unusable. Perhaps there is a slot in the styrofoam base allowing you to use the remote, I just can't remember. However, you should be able to get to the hard buttons on the back of the TV. If so, they will allow you to access the menu for input selection and screen wipe, but the remote would be a lot easier.
There are setup items. I can't remember if you can defer them. Sorry.
The box has 4 plastic plugs which secure the top and bottom box halves together. They can be put back in as long as you didn't tear the box taking them out. Follow the directions on the plugs/box when removing them. So you shouldn't need to use rope, unless you just want to be extra careful. Just make sure you re-clamp the plastic plugs properly. I remember having to examine them to understand how they worked.
Panasonic TC-P60ZT60 plasma panel
Sony BDP-S5500 Blu-ray player
Arris DCX3600-M DVR
Yamaha RX-V650 AVR
XBox One
URC MX-780 remote control
sooke is offline
Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv
