Same Price - 60" ST60 VS 65" S64 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-01-2013, 11:45 AM - Thread Starter
mraya77's Avatar
Hi Everyone,
What would you do in this situation??
I have an opportunity to purchase a 65" S64 or a 60" ST60 for virtually the same price.  Do you think the extra 5" of the S64 is more beneficial than the better picture picture quality offered by the ST60 or do you think the better picture quality of the ST60 is more beneficial than the extra 5" of the S64?  Thanks!
I will be sitting somewhere between 10 - 12 feet away from the screen.  I am in the midst of creating a new living room for myself and am still trying to figure out the furniture setup.
mraya77 is offline
post #2 of 11 Old 11-01-2013, 12:14 PM
chunon's Avatar
Quoted: 2013 Post(s)
Liked: 1774
Go 65" at that distance
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 11 Old 11-01-2013, 12:50 PM
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 70
What size at 7 feet?
RicFlair is offline
post #4 of 11 Old 11-01-2013, 01:14 PM
angle_theory's Avatar
60", recommended range for 65" is 8'+
angle_theory is offline
post #5 of 11 Old 11-01-2013, 01:17 PM
chunon's Avatar
Liked: 1774
I'll second that 60" or 55"
65C6 OLED
post #6 of 11 Old 11-01-2013, 01:35 PM
True, but from what I've seen the best value play is 60" because there isn't much of a price jump between 55" and 60" but a huge price jump from 60" to 65". So as long as you can physically fit a 60" screen and are within the recommended seating distance, it's pretty much always the better buy.
post #7 of 11 Old 11-01-2013, 01:49 PM
AKA
AKA's Avatar
Liked: 36
My advice - go and view a ST60 and S60 in person. I found myself looking at both models you mention. However, I found a noticeable difference with regard to banding and motion, in favor of the ST60. I also taped off both dimensions on the wall to visualize the size difference. After doing this, I decided the difference in dimension was more than made up for by better PQ on the ST60.
That said, both are great values and both should work fine for that space.
AKA is offline
post #8 of 11 Old 11-01-2013, 07:22 PM
PlasmaPZ80U's Avatar
Quoted: 1964 Post(s)
Liked: 560
what kind of source feed were you watching? I'm curious
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #9 of 11 Old 11-02-2013, 12:59 PM - Thread Starter
mraya77's Avatar
Thanks guys.  If anyone else would like to share their thoughts on this, please do.  Much appreciated.
mraya77 is offline
post #10 of 11 Old 11-04-2013, 09:17 AM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
At that distance I wouldn't go below 65"
sheshechic is offline
post #11 of 11 Old 11-04-2013, 12:06 PM - Thread Starter
mraya77's Avatar
Thanks!  I recently taped off the dimensions of the 60" and the 65" and I was a bit surprised to see that the difference in size was not as much as I thought it would be.  The 65" just didn't seem to be that much bigger than the 60".  Of course, judging it from looking at a taped outline might be somewhat deceiving.
I must admit that what AKA says above does hit a chord with me as I do hate banding and motion blur.  On the other hand, perhaps because of the distance I am sitting, the 65" should be the way to go regardless of the increased visual benefits of the ST60.  Thanks again for sharing your opinion.
Question to all - I noticed on the Panny specs that the ST60 has about double the amount of shades of gradation as the S64.  But, in everyday reality, does that really mean that the ST60 will show gradation twice as good as the S64 will show it?
mraya77 is offline
Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv
