50" TC-P50S60 v. TC-P50ST60 question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-04-2013, 08:59 AM - Thread Starter
jonandabby's Avatar
I’m looking at a 46” – 50” TV. It will be going in a bedroom and the wall that will have the TV is far away from where the bed will be (about 15 or so). I’m thinking a plasma TV is fine, since there will almost never be a time when I’ll be using the TV when there is any sunlight to worry about. I don’t need ANY internet gizmos in the bedroom. I just need a good picture for the high def cable box and the occasional blu-ray.. I'm thinking that since I just need a good picture and not much else, the TC-P50S60 is probably enough.
1) Am I right that the S60 series is enough for my purposes?
2) Are there any other equivalent sets I also should be considering?
jonandabby is offline
Panasonic Tc P50s60 50 Inch Plasma Hdtv , Panasonic Tc P50st60 50 Inch 3d Smart Plasma Hdtv
