Shades of Gradation - ST60 VS S60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 11-04-2013, 10:42 PM - Thread Starter
mraya77's Avatar
Hi Guys,
Panny claims the ST60 to have double the amount of shades of gradation than the S60/S64.  Have any of you had the opportunity to experience both the ST60 and the S60/S64 and experienced first hand the shades of gradation performance difference for these two TV's?  Is the difference significant from what you experienced?  Thanks!
mraya77 is offline
post #2 of 16 Old 11-05-2013, 05:44 AM
chunon's Avatar
Quoted: 2038 Post(s)
Liked: 1784
Look for a comparison thread one was done fairly recently. But to answer your question you will some some slightly smoother transitions because of the shades or gradation but it is not readily apparent in all material. In my estimation there is a certain amound of marketing hype in the some of the features that are different between the two sets.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 16 Old 11-05-2013, 09:10 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
I have to agree. You will find slightly better color gamut (less banding) and shadow detail. However, higher brightness and contrast is what gives the ST60 the real edge.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #4 of 16 Old 11-05-2013, 09:22 AM
chunon's Avatar
Liked: 1784
65C6 OLED
post #5 of 16 Old 11-05-2013, 09:38 AM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
Ian
aren't the color gamut and banding two separate things? I get near perfect measurements for gamut on my S60 (including luminance and saturation sweeps) but looking at gray, red, green, and blue continuous ramps reveals a lot of banding (including color banding with gray)
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #6 of 16 Old 11-05-2013, 09:42 AM
chunon's Avatar
Liked: 1784
Yes to my knowledge the banding would be more impacted by the shades of gradation
65C6 OLED
post #7 of 16 Old 11-05-2013, 09:51 AM
Liked: 562
that's what I thought too
post #8 of 16 Old 11-05-2013, 10:16 AM
chunon's Avatar
Liked: 1784
Do you see the banding in cotent or just the gray scale ramp ?
65C6 OLED
post #9 of 16 Old 11-05-2013, 10:19 AM
Liked: 562
both, though it's more random in content than consistent (usually smooth transitions of a single color)
FWIW, my 2008 Panasonic Plasma has it too (TH-42PZ80U).
post #10 of 16 Old 11-05-2013, 10:22 AM
chunon's Avatar
Liked: 1784
Maybe I am just not sensitive to it have yet to notice it on the ST60
65C6 OLED
post #11 of 16 Old 11-05-2013, 11:30 AM - Thread Starter
mraya77's Avatar
Ian
Hi Ian,
Do you know why the ST60 is brighter?  Does the higher contrast ratio of the ST60 also help to increase the brightness?
mraya77 is offline
post #12 of 16 Old 11-05-2013, 12:37 PM
chunon's Avatar
Liked: 1784
My guess is less agressive abl, and the brightness is the top end component used to calculate contrast ratio, it is not as important as black level but it still is partially responsible for the increased contrast ratio over the S60
65C6 OLED
post #13 of 16 Old 11-05-2013, 01:46 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Sorry, I didn't word that correctly. I meant to post less color banding. Not sure how gamut got in there. confused.gif
mailiang is offline
post #14 of 16 Old 11-05-2013, 05:03 PM
Liked: 562
no worries
post #15 of 16 Old 11-05-2013, 05:04 PM
Liked: 562
I turned on deep color on the PS3 today and while it didn't help with BDs, the XMB showed much less color banding.
post #16 of 16 Old 11-05-2013, 05:06 PM
Liked: 562
Originally Posted by mraya77 View Post
Hi Ian,
I think it's the better 'neoplasma' panel
the black level difference is mainly due to the black filter (infinite black pro) being a little darker
Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic 60 Inch Plasma Hdtv Tc P60s60
