Panasonic Plasma 42" Display screen TH-42PW5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-06-2013, 05:41 AM - Thread Starter
John Symons's Avatar
how do i connect a dvd player to this screen it has a row of plugs on the back  i have seen it working but the previos owner has disconnected everything an i dont know where all the plugs go
John Symons is offline
post #2 of 3 Old 11-06-2013, 07:44 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
It would be helpful if you would include a picture of the "row of plugs" so we could identify them, but if memory serves me correct that monitor has a Component Video input terminal board with at least three BNC inputs (one /R, one /B, and one /G which will be for the Red/Blue/Green video cable). There should also be two audio inputs on that board - either Red/White RCA or they could also be BNC.
If you want to connect a regular DVD Player using regular Red/Blue/Green Component Video cables, you'll need to buy some BNC-to-Female RCA adapters (like the Monoprice # 4121 below) to connect the R/B/G video cables to the BNC inputs.
There should also be another board with one or two VGA inputs, and you can also use the VGA input to display Component Video by using a VGA-to-RCA RGB Breakout Cable (like the Monoprice # 2170 below), then go into the display's setting and change the signal type for that input from PC to Component.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 3 Old 11-07-2013, 12:17 AM - Thread Starter
thanks all sorted
regards
john
Panasonic
