Question about blu-ray vs broadcast aspect ratio and black bars - AVS Forum | Home Theater Discussions And Reviews
Old 11-08-2013, 05:10 PM - Thread Starter
johnmalcovich's Avatar
While I was watching Step Brothers on FX it occurred to me that many movies on broadcast don't have black bars, but they don't look like they have been cropped/pan and scanned either. To make sure I compared the broadcast version of Step Brothers with my blu-ray copy, and the width of the picture is the exact same, the difference being the black bars on the blu-ray version-there seems to be more picture in the height of the picture also, almost as if the black bars are taking away picture vertically.
My question is, how do they remove the black bars for the broadcast version while still seemingly retaining the aspect ratio? I understand the reason for black bars (2:40:1 AR), so how is it possible to present the movie otherwise, without distorting the picture.
Thanks to anyone who can answer!
johnmalcovich is offline
Old 11-08-2013, 05:54 PM
nrighton's Avatar
Most movies are filmed in full frame 1.33:1 aspect ratio (think old nearly square TV. The implementation of the wide screen aspect ratio occurs in post production. The final aspect ration is up to the directors discretion. They crop the top and bottom to fit the aspect ratio desired. The can create different versions of the film because of this. They can create a 16:9 version for HDTV broadcast and a wider 2.40:1 version for cinema. Hope this helps.
Nick
Justified By Faith
nrighton is offline
Old 11-10-2013, 05:02 PM - Thread Starter
That makes sense thanks!
