plasma picture help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-08-2013, 06:53 PM - Thread Starter
swc11's Avatar
I have a 50 inch plasma samsung hp-s5053. The picture quality seems to be steadily getting worse. It has red and green pixel dots all over and the picture looks grainy. Here is a couple up close pics that were taken while playing a bluray disc. Cable tv is worse. Is there anything that can be done to fix this [IMG][IMG]cheaply?
swc11 is offline
post #2 of 7 Old 11-08-2013, 06:54 PM - Thread Starter
swc11's Avatar
swc11 is offline
post #3 of 7 Old 11-09-2013, 06:54 PM - Thread Starter
swc11's Avatar
Can anything be done? Or should I just buy a new set?
swc11 is offline
post #4 of 7 Old 11-10-2013, 02:28 PM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
I can't really tell what you're trying to show. but I'm sure posting your picture settings would be a great help.
especially things like sharpness, or any processing(NR, dynamic contrast, etc)
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #5 of 7 Old 11-10-2013, 09:08 PM - Thread Starter
swc11's Avatar
swc11 is offline
post #6 of 7 Old 11-10-2013, 09:09 PM - Thread Starter
swc11's Avatar
swc11 is offline
post #7 of 7 Old 11-11-2013, 01:01 PM
fierce_gt's Avatar
Liked: 1570
ok, well, I would start by getting out of dynamic(use movie or standard), drop the sharpness to 0(I would never go above maybe 10-15 on a Samsung, even at 0 they seem to add artifacts in some cases), turn off the digital NR and whatever that setting is below it.
please be patient with this. the picture will probably look 'terrible' to you as you are used to some very different settings. but try it and see if it helps with your problems. if you really want to go back to some of the old settings, ok, try changing them back one at a time and see if it makes your issues return. I suspect the sharpness is the biggest problem, but it's hard to know for sure.
I would also recommend trying a calibration disc, or even just looking up some other users settings for your tv and give them a try. it looks like your display is set pretty far away from 'reference'. it may take a bit to get used to, but most ppl find it a much more pleasing image once they do.
Samsung Hp S5053 50 Inch Plasma Hdtv
