Audio out to a reciver on a TC-P60ST60 TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-10-2013, 02:21 PM - Thread Starter
steven01's Avatar
I have Netfix on my TC-P60ST60 television. I want to have the sound to go to my receiver and then to my 5.1 speakers. I tried using the HDMI 1 port, but it's not working.
It that only for inputting a signal, or can the tv send the signal out to the receiver that way? How do I get sound out to a receiver?
steven01 is offline
post #2 of 6 Old 11-10-2013, 04:35 PM
jp0213x's Avatar
Make sure the HDMI is plugged into the ARC hdmi port. Then you may have to go into your receiver to enabled arc for the HDMI. If you have a Yamaha you will need to enable arc from the hdmi menu.
jp0213x is offline
post #3 of 6 Old 11-12-2013, 06:22 AM - Thread Starter
steven01's Avatar
I tried it and it worked just fine. Thanks for the help!
steven01 is offline
post #4 of 6 Old 11-12-2013, 11:51 AM
PlasmaPZ80U's Avatar
Quoted: 2293 Post(s)
Liked: 706
do you get 5.1 channel audio on your receiver this way or just 2.0?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #5 of 6 Old 11-13-2013, 12:30 PM - Thread Starter
steven01's Avatar
I got 5.1 this way. I have a Pioneer VSX1122K. It's 7.1, with 2 channels going to speakers in the backyard.
steven01 is offline
post #6 of 6 Old 11-13-2013, 01:09 PM
Liked: 706
I tried it myself and I do get 5.1 too. However, what should be DD+ is converted to DD with Netflix Streaming. Also, I can get "1080 Super HD" with my PS3 but just "1080 HD" with my S60 (I tried using Ethernet and it still didn't go to 1080 Super HD).
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv
