Panasonic ST50 display settings change with Netflix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-12-2013, 06:40 PM - Thread Starter
RandyYoung's Avatar
Hello. I am such a novice, so please forgive a possibly simple problem. I have followed some recommendations for display settings and am happy with overall viewing of HD cable and DVDs. However, when I hit the Netflix button and watch content the screen darkens and appears to be "green" saturated. Why would the display settings change with Netflix? Anyone have a possible solution?
RandyYoung is offline
post #2 of 4 Old 11-12-2013, 07:54 PM
nrighton's Avatar
Each input including netflix has it's own picture settings. You need to adjust or copy / paste the settings you want by pressing the menu button on the remote with the netflix app running then select picture. Hope this helps.
Nick
RandyYoung likes this.
Justified By Faith
nrighton is offline
post #3 of 4 Old 11-13-2013, 08:29 AM - Thread Starter
RandyYoung's Avatar
As a further testament to my newbness, I can't even accurately describe my TV. It is an ST60 not an ST50. Either way, your advice worked. Thank you so much for the quick reply. I was able to greatly improve my Netflix display. I'm sure as I try to learn more about the TV and optimize the settings, I'll have more questions. Nice to know there is a helpful and knowledgeable forum here.
post #4 of 4 Old 11-14-2014, 04:47 PM
thepiecesfit's Avatar
Too bad Netflix output is 60hz for 3d there is way too much crosstalk. 48hz is needed for a good 3d experience.
thepiecesfit is offline
Panasonic Tc P50st60 50 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P50st50 Plasma Tv , Panasonic Viera Tc P65st50 Plasma Tv , Panasonic Viera Tc P55st50 55 Inch Plasma Tv , Panasonic Viera Tc P60st50 Plasma Tv
