Plasma Causing Hum in Amps - AVS Forum | Home Theater Discussions And Reviews
Old 11-21-2013, 03:04 PM - Thread Starter
slovell1's Avatar
I'm getting an oscillating hum from my Adcom amps whenever I turn on my Panasonic plasma tv. The hum isn't coming through the speakers, but from the amps themselves. I turn on the tv and the amps hum, I turn the tv off and the hum from the amps disappears. I'm stumped. The amps and the tv are plugged into separate outlets on different walls in the room. Does anyone have any advice as to how to fix this?
slovell1 is offline
Old 11-21-2013, 03:43 PM
lentiman's Avatar
Sounds like you may need a ground loop isolator or equivalent. The easiest way to test this is get a grounded to ungrounded (i.e. three female prong to two male prong) adapter at Home Depot and plug it into your amp power plug then plug that into the wall. Then turn on the plasma and see if you still get hum. I had a subwoofer that did this and that fixed it. There are other fixes also, but this is the least expensive. Insert warning about surge protection and such here.
lentiman is offline
Old 11-21-2013, 03:50 PM - Thread Starter
slovell1's Avatar
The plugs on the amps and tv are all two prong male. Should I try a two female to three male adapter? Do they even make these? I've seen the three female to two male but I don't recall seeing the two female to three male.
slovell1 is offline
Old 01-19-2014, 05:34 PM
ginospin's Avatar
Maybe you have resolved issue. I had same problem with new panasonic plasma and emotiva amps.
I plugged tv in outlet on different circuit while everything else remained same, problem gone.
ginospin is offline
Old 01-22-2014, 12:10 AM - Thread Starter
slovell1's Avatar
I bought a Humbuster from AVA Audio which completely eliminated the hum. It's not often you actually get what you paid for.
Regards, Sam
slovell1 is offline
Plasma Hdtv
