Samsung PS51E557 calibration problem. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-22-2013, 11:12 AM - Thread Starter
Motka's Avatar
Hi...I have some calibration problem on my TV...Changes of brightness and Cell light have no result on bright picture. Also I have very agressive Auto Bright Limmiter(ABL), and its too stroby on ice hockey....
http://motkarast.ucoz.ru/bright.gif
http://motkarast.ucoz.ru/cell.gif
http://motkarast.ucoz.ru/bad1.gif
Can I change something in Service menu(may be in advanced, panel type or else) to calibrate ABL? Is it warianty case? Any suggestions?
Thank You....
Motka is offline
post #2 of 7 Old 11-22-2013, 12:27 PM
chunon's Avatar
Quoted: 2015 Post(s)
Liked: 1775
ABL is not configurable
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 7 Old 11-22-2013, 12:51 PM - Thread Starter
Motka's Avatar
can I turn of it from advanced service menu? Is my videos  normal?
Motka is offline
post #4 of 7 Old 11-25-2013, 12:16 PM - Thread Starter
Motka's Avatar
My problem is something like that
http://www.youtube.com/watch?v=E3_xN2xs2vA
Any idea?
Motka is offline
post #5 of 7 Old 11-25-2013, 12:57 PM
willieconway's Avatar
Quoted: 121 Post(s)
Liked: 130
You're looking at ABL which is normal and can't be turned off. If I remember correctly it's less agressive if you set cell light to maximum. Also, in your first post you're moving the brightness control which affects black level, not light output. Use the contrast control for that.
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D. Currently boxed up: Denon 1713, Klipsch SW-450,
NHT Absolute Center, Energy Veritas 5.1s, 5.2C, V-Mini-C.
willieconway is offline
post #6 of 7 Old 11-25-2013, 11:59 PM - Thread Starter
Motka's Avatar
That pops increses when contrast is lower than 70, but picture is awfull. Cell light can't change anythig.
Motka is offline
post #7 of 7 Old 11-26-2013, 06:32 AM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
I did not look at video.On samsung 51pne450 here I don't notice popping with hockey unless I'm really looking for it and sitting close.I did notice it a bit when I first got it,but it was not bad enough too return it.Maybe it's worse when tv is new,as plasmas take a while too settle..::...Some have tried different firmwares,but you risk having other problems if you do it.Maybe try different settings...If it's really noticeable,then return it.
Vic12345 is offline
Samsung
