F8500 and WMN350M (or perhaps another mount) - AVS Forum | Home Theater Discussions And Reviews
Old 11-27-2013, 04:13 PM - Thread Starter
toxic's Avatar
I just picked up the 65" F8500 and am looking to mount it on the wall. I would love to have a flush mount and found the Samsung WMN350M, however the specs don't mention Plasma TVs. To further my conundrum, the reviews on Amazon say this mount is incredibly difficult to work with due to poor instructions and that it is next to impossible to get the TV out of the mount once it is in.
I think that the wall I would like to mount my TV on may not have stud access in the desired spots for the mount, so I may need to use some sort of hollow wall anchors or toggle bolts. I am extremely worried about my TV coming crashing down to the ground.
Any wall mount guidance and suggestions on the above mentioned mount or any others would be MUCH appreciated.
toxic is offline
Old 04-29-2014, 10:37 AM
Knocks's Avatar
Hi there. Which mount did you end up using for your TV?
Knocks is offline
Old 05-17-2014, 11:35 AM
Patwrightjr's Avatar
I used a universal mount from best buy that work up to a 70"and the versa pattern (for my 60"f8500). Remember these tvs run hot so they need some space away from the wall the breath. No studs is a no go
Patwrightjr is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
