Help! New Panasonic 50st60 picture has visible picture noise and is too dark - AVS Forum | Home Theater Discussions And Reviews
Old 12-12-2013, 11:19 PM - Thread Starter
kevgees's Avatar
I just purchase the panasonic 50st60 and its a great tv. I just for rid of my 14 year old panasonic pwdy7 tv i think it was. My old panasonics tv picture looks way better than the 50st60 right now! I know it shouldn't so I want to know if anyone has good calibration settings to get my the best picture on the tv. The picture right now is too blurry and too dark. Some stuff looks old on it and some dent! Please help!!
kevgees is offline
Old 12-13-2013, 02:23 PM
hungro's Avatar
Quoted: 164 Post(s)
Liked: 111
Hello, I have the ST60. First, switch to Cinema mode and change your gamma setting to 2.6. Set panel brightness to mid. Turn off all your enhancements for noise reduction , agc, black extension etc. Get AVS HD 709 calibration disk and set up your basic picture settings. Contrast, Brightness, Color/Tint, and Sharpness using the provided patterns on the disk. This will get you closer to a better picture. Some people are trying D'nices ST60 settings but it's basically a crap shoot whether they will improve the picture or make it worse then factory defaults. I tried them and they made everything , including the blacks too red. I do have a calibration meter so I can verify that his settings on my set are actually worse then factory defaults.
hungro is offline
Old 12-13-2013, 02:53 PM
benz5521's Avatar
Quoted: 42 Post(s)
Liked: 32
I have an ST60 too and read elsewhere that the gamma setting should be 2.4. What's the difference? I have no clue what the gamma setting does.
benz5521 is offline
Old 12-13-2013, 03:34 PM
smurraybhm's Avatar
Quoted: 1470 Post(s)
Liked: 1760
Using the search tool on AVS can be very helpful. A great way to learn more about your display and calibration in general is to spend some time over on the calibration thread.
http://www.avsforum.com/t/1505120/gamma-bt-1886-explained-lightspace-users-check-in-here-need-your-help
RIP Cricket - my pug and little buddy Jan. 10, 2017
Panasonic 60VT60 (cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 w/ 2500+ blu-rays and growing. Yes I still have HD-DVDs too.
smurraybhm is offline
Old 12-13-2013, 04:00 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
Old 12-14-2013, 06:28 AM - Thread Starter
kevgees's Avatar
AVS HD 709 calibration disk?
kevgees is offline
Old 12-14-2013, 09:47 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration/0_100
mailiang is offline
Panasonic Tc P50st60 50 Inch 3d Smart Plasma Hdtv
