Samsung 51" PN51F5300 vs Panasonic 50" TC-P50S60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-14-2013, 02:55 PM - Thread Starter
adamw5963's Avatar
I have been considering upgrading to a 50" TV. So far I have narrowed it down to the Panasonic 50" TC-P50S60 for $699 or the Samsung 51" PN51F5300AFXZA for $649. So I guess the biggest question is: is the Panasonic worth the extra $50 and loss of an extra inch of size? From what I've read the S60 is a great TV (only with some issues in very bright rooms) but I have been having a very hard time finding any info on the F5300. I know Panasonic's Plasmas are widely considers one of the best plasmas available (I certainly love mine), but Samsungs are also considered very high quality, correct?
And I don't care about 3D (can't see it) or smart tv features (xbox, ps3 for that) or lots of hdmi connections or speaker quality (a/v receiver). I'm really just interested in the best picture quality for my buck.
adamw5963 is offline
post #2 of 9 Old 12-14-2013, 03:08 PM
RWetmore's Avatar
Quoted: 414 Post(s)
Liked: 220
Yes, the Panasonic is better. Much deeper blacks and finer adjustments (i.e. Pro Settings with Color Management), though the Samsung does have a 10 pt. greyscale adjustment.
RWetmore is offline
post #3 of 9 Old 12-14-2013, 03:11 PM
mailiang's Avatar
Quoted: 970 Post(s)
Liked: 641
Does anyone else here have problems reading the OP's remarks?
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #4 of 9 Old 12-14-2013, 03:26 PM - Thread Starter
adamw5963's Avatar
Lol sorry didn't mean to make that confusing.
post #5 of 9 Old 12-14-2013, 03:34 PM
mailiang's Avatar
Quoted: 970 Post(s)
Liked: 641
Confusing? I have to hit select to make out the print. (I'm using AVS retro black ). Not sure what the problem was.
Ian
mailiang is offline
post #6 of 9 Old 12-14-2013, 03:42 PM - Thread Starter
adamw5963's Avatar
Hmmm. I don't know why. It looks the same on my end.
post #7 of 9 Old 12-14-2013, 03:46 PM
RWetmore's Avatar
Quoted: 414 Post(s)
Liked: 220
No.
RWetmore is offline
post #8 of 9 Old 12-14-2013, 03:47 PM
mailiang's Avatar
Quoted: 970 Post(s)
Liked: 641
You're print is fine now. Must be some kind of glitch with the retro setting when you posted it. BTW, I have extensively viewed both these sets and IMO, the S60 has the edge.
Ian
mailiang is offline
post #9 of 9 Old 12-14-2013, 03:58 PM - Thread Starter
adamw5963's Avatar
Ok thanks for the input. I figured it was probably the better of the two. Do you have any experience with gaming on them?
Samsung Pn51f5300 51 Inch Plasma Hdtv , Panasonic Tc P50s60 50 Inch Plasma Hdtv
