Panasonic TC-P65ST60 question about 24p Direct in mode - AVS Forum | Home Theater Discussions And Reviews
Old 12-17-2013, 05:35 PM - Thread Starter
phelan013's Avatar
Panasonic TC-P65ST60 question about 24p Direct in mode.
I recently purchased this TV and am happy with everything but one thing.
I like watching movies with no motion smoothing nor motion blur setting adjustments.
I noticed when watching blu-ray's it forces the 24p Direct in mode on and gives you options of 48hz, 60hz, 96hz. I bleive this is causing the issue for me.
I may be in the majority but i like my movies to have the normal amount of motion blur and no additional settings for sharpness or interpolation, etc.
Is there a way to turn this setting off or make it so that this motion smoothing is not present? I have already turned off the other motion smoothing setting.
Thank you for any advice,
Jesse
phelan013 is offline
Old 12-17-2013, 06:27 PM
RWetmore's Avatar
Quoted: 264 Post(s)
Liked: 162
You must have the ST60 because there is no option for 96Khz on the S60.
RWetmore is offline
Old 12-17-2013, 06:40 PM - Thread Starter
phelan013's Avatar
I am sorry, Yes i have the P65ST60.
Jesse
Old 12-17-2013, 06:46 PM
mrfattbill's Avatar
Quoted: 73 Post(s)
Liked: 79
Just try each one and see which you prefer. I like the 96, 48 flickers and 60 you might as well not bother having 24p on at all.
Bill
mrfattbill is offline
Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65s60 65 Inch 1080p 600hz Plasma Hdtv
