Panasonic 60ST60 dull whites - AVS Forum | Home Theater Discussions And Reviews
Old 12-22-2013, 12:58 PM - Thread Starter
Tcaine5's Avatar
Just bought the Panasonic St60 60 inch and the blacks are great. My problem is with the whites, specifically of ice in watching ice hockey. Is there a adjustment that I am missing or a recalibribration that will make the ice look white. Even vivid looks somewhat gray and or foggy. Do I need to get an LCD LED TV to watch hockey?
Love everything else about the TV.
Tcaine5 is offline
Old 12-22-2013, 01:48 PM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4959 Post(s)
Liked: 8384
That's the effect of auto brightness limiting that you are noticing. If you want super-bright whites when watching hockey then you'll (probably) have to look at an LCD model, or spring for a Samsung F8500 plasma. However it'll be tough (i.e. impossible) to find something that can match the ST60 in other picture-quality categories at the same price.
Cuda1169 likes this.
Mark Henninger
imagic is offline
Old 12-24-2013, 04:21 PM - Thread Starter
Tcaine5's Avatar
Thanks for your input. I can get get some of the gray put by adjusting the pro settings in custom by increasing AGC, black extension, and gamma to 2.6 in gamma detail adjustment/ i have left panel brightness on mid. I assume there is no way to turn off auto dimming? Is there a way to tweak the black // white detail adjustment as well. Unfortunately,, the hockey settings don't help the football picture ( I like the native custom setting). For movies, the cinema with D nice settings and home theater work well.
I have considered switching to the sony kdl 55 802a as well.I could look at a smaller samsung 8500 too.
Tcaine5 is offline
Old 12-24-2013, 04:44 PM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
You have CATS turned off and Power Saving (in Eco Settings) set to 'Standard', right?
RWetmore is offline
Old 12-24-2013, 07:44 PM
benz5521's Avatar
Quoted: 42 Post(s)
Liked: 32
Turn up the contrast.
benz5521 is offline
Old 12-26-2013, 05:46 PM - Thread Starter
Tcaine5's Avatar
I have CATS off and powersaving eco at standard. Contrast is between 79-100%. I am adjusting the custom mode settings.
Tcaine5 is offline
Old 12-26-2013, 05:51 PM
wxman's Avatar
Quoted: 3536 Post(s)
Liked: 2553
Perhaps there is a way to get into the service menu and turn ABL off. I know with my old Pioneer 5020, one can get into service menu and basically set it to a much higher value to keep ABL from kicking in. Kept the same blacks and produces a much brighter image with white backgrounds.
LG 65EF9500
LG 65E6P
wxman is online now
Old 12-26-2013, 06:26 PM
chunon's Avatar
Quoted: 2021 Post(s)
Liked: 1777
There is no abl adjustment in the service menu or anywhere else
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv
