Wall/ceiling mounting options for 55 or 60" panel - AVS Forum
post #1 of 5 Old 12-27-2013, 10:09 AM - Thread Starter
implosive's Avatar
I do not currently have a TV, but I'm thinking about getting one soon (perhaps a VT60 at around 55 or 60"). My main obstacle is figuring out how to mount it. I don't wish to dedicate the floor space to just a TV, so I'd like to mount it either on the wall or from the ceiling. This is where it gets tricky: I have a standing desk basically right where it would make sense to put the TV, and I don't particularly wish to give that up.
As far as I can tell, the two options I have are:
- A ceiling mount that can go up and down to get the TV out of the way when it's not in use.
- A full-motion arm that could swing forward and down to place the TV at viewing height (in front of my computer monitors on the standing desk) when in use, then back up and away when not in use.
A 60" VT60 is 80.5lbs (http://shop.panasonic.com/docs/cutsheet/TCP60VT60_Cutsheet.pdf) and a 55" is 69.5lbs (http://shop.panasonic.com/docs/cutsheet/TCP55VT60_Cutsheet.pdf). As far as full-motion arms go, this puts the 55" barely within spec for the Ergotron VHD (http://www.ergotron.com/ProductsDetails/tabid/65/PRDID/623/language/en-US/Default.aspx) or the OmniMount Play70DS (http://www.omnimount.com/products/tv_wall_mounts/interactive/play70ds/).
Ceiling mounts also are a little tricky for me because I have a cathedral ceiling (the ceiling angles up towards a central joist). In this wall's case, the angle of the ceiling gets higher as you move straight back from the wall (as opposed to moving side to side along the wall). There are joists that go up along the ceiling that would be a great thing to bolt into, but all the ceiling mounts I've seen (e.g. http://www.omnimount.com/products/ceiling_and_projector_mounts/ceiling_mounts/scm125/ or http://www.sanus.com/us/en/products/visionmount/ceiling-mount/LC1A or http://www.ergotron.com/ProductsDetails/tabid/65/PRDID/628/language/en-US/Default.aspx) need to bolt into something that's perfectly horizontal, not at an angle or into the side of something.
Any suggestions on how best to move forward? Thanks!
implosive is offline
post #2 of 5 Old 12-27-2013, 11:41 AM
Latinoheat's Avatar
Quoted: 48 Post(s)
Liked: 132
Post a pic of your room.
TV - Panasonic 55GT50Main Speakers - Klipsch Gallery G28'sCenter Channel- Klipsch RC-52Sub - Klipsch Sub 12Surrounds - Klipsch RS-52 II (new)Bluray/Game - HTPC/PS3Receiver - Onkyo RC-360HTPC - Intel Core i3, HDMI,Windows 7,XBMC,Bluray,3 TB,wireless WMC keyboardVideo processor - Darbee
Latinoheat is online now
post #3 of 5 Old 12-27-2013, 12:25 PM - Thread Starter
implosive's Avatar
I'm away from home at the moment but here's an old pic I butchered to show what things are like now.
post #4 of 5 Old 12-27-2013, 03:22 PM
Latinoheat's Avatar
Quoted: 48 Post(s)
Liked: 132
why can"t you just move your cabinet over to the side and mount your tv at eye level? I think it would look odd with monitors on the desk and a tv on top, honestly.
post #5 of 5 Old 12-27-2013, 05:06 PM - Thread Starter
implosive's Avatar
That's a fair question, but I really like my standing desk where it is. :) If I moved it over, it would block the light from the window to its left, and that'd be a shame. I'm not too worried about it looking odd; I'd rather have it be functional. I'll most likely use the TV infrequently at most, so I want my desk to still be fully useful.
One possibility would be to use something like http://www.homedepot.com/p/Simpson-Strong-Tie-Z-Max-4-in-x-4-in-Uplift-Post-Base-ABU44Z/100375358?keyword=abu44 (appropriately spray painted to match the wood) to have something horizontal for the top of a ceiling mount to bolt into.
Are there ceiling mounts that can be raised and lowered easily (i.e. without tools using only hand pressure)?
Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv
User Tag List
