Panasonic VT65 - motion problems. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-27-2013, 05:52 PM - Thread Starter
DigitalReaper's Avatar
Hi there,
I upgraded to the TX-P50VT65 from a 42" PX85 Panasonic plasma in October this year as i'd been suitably impressed with the 85s performance. However i'm faced with some issues :
In all source material (HD/SD broadcasts and blu-rays @ 24Hz) - camera panning or motions moving past a fixed camera introduce a very noticeable 'judder' or extra frame behind the actual object - now from the reviews i've read and responses i've gained I get conflicting information - this is either acceptable 'telecine' judder, or a faulty set as its motion should be as smooth as silk. How can some reviews say it has sublime motion handling when it looks shaky / judder / stuttery as soon as something moves?
What are your thoughts?
I currently use THX cinema settings, with sharpness turned down to 0 and all panel processing features off. Broadcast source is free view and free view HD, blu-ray sources are PS3 / PS4.
Regards
Anthony.
DigitalReaper is offline
post #2 of 3 Old 12-28-2013, 05:18 AM - Thread Starter
Anyone?
post #3 of 3 Old 12-28-2013, 08:44 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 520 Post(s)
Liked: 775
Originally Posted by DigitalReaper View Post
Anyone?
AVS Forum covers North American models, but TX-P50VT65 is not a North American model so it's not likely you'll find any owners here.
Since your model numer doesn't have a B at the end of it i presume it's an Australian/NZ model, and if so it would be more similar to the UK and European models (all of which are 240 volt / 50Hz). NA models are 120 volt / 60Hz.
There is a good UK-based Plasma forum that covers UK models and most European models so maybe you'd have better luck there:
http://www.avforums.com/forums/plasma-tvs.82/
Cheers !
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv
